pin names for the stamp2
I usually use the stamp1, but in this project i am using the stamp2
and am having trouble figuring out how to assign the i/o pins
meaningful names.
say for example that I have three pins that I wan to assign names:
many CON 0
moe CON 1
jack CON 2
and I also want to give on and off states meaninful names
light CON 1
nolight CON 0
obviously, one can see that I am doing something wrong, but i can't
seem to find any reference in any of the books on the stamp that I
own.
how to I name the stamp2's pins?
thank you for any assistance
p_stout@j...
meaningful names.
many CON 0
moe CON 1
jack CON 2
light CON 1
nolight CON 0
own.
p_stout@j...
The CON is just a compiler directive which means 'constant'. That means that
when you use the symbol (jack for example), it will be replaced (at compile
time) by the value you specified into the declaration of the constant.
Example :
light CON 1
radio CON 2
TV CON 3
high light ' set pin 1 high : turn on the light
low radio ' set pin 2 low : turn off the radio
high TV ' set pin 3 high : tunr on the TV
This can be useful to parametrize a program :
MaxOpt CON 5 ' maximum value of an option
Option VAR byte
if option>MaxOpt then ...
If you use MaxOpt everywhere in your program, it will be easy to change the
number of options (for this example) by changing only the value of the
constant (instead of searching-replacing all lines containing '5'...)
Hope this is understandable, I'm more used to french...
Best regards,
Philippe Derenne
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, August 22, 2000 2:10 AM
Subject: [noparse][[/noparse]basicstamps] pin names for the stamp2
> meaningful names.
> many CON 0
> moe CON 1
> jack CON 2
> light CON 1
> nolight CON 0
> own.
> p_stout@j...
writes:
That depends on how you want to use them. For HIGH and LOW, you can use
simple, numeric defintions:
MyLight CON 0
HIGH MyLight ' light on
LOW MyLight ' light off
Most of the time, however, you'll want to do this:
LightOn CON 1
LightOff CON 0
MyLight VAR Out0
Then you can write your code like this:
MyLight = LightOn
Of course, you'll have to define you inputs and outputs as needed.
-- Jon Williams
-- Dallas, TX
