Instrument Development
I would like to build a set of instruments to read eight
sensor inputs (0-5vdc real time) then translate that
information to drive eight R/C servo motors that will
position dial indicators showing the input values. In your
opinion what equipment will I need to do this.
I am not familiar with the Basic Stamp other than its
existence. Any information and/or resources would also be helpful.
It seems that this should be an easy thing to do!? These
instruments will be in a harsh environment, i.e.. vibration,
electrical noise, 0-50C, and need to be small in size.
Any help will be much appreciated.
Sincerely,
Dave
Sincerely,
Dave
The MAX186 is a 12-bit - serial - 8-channel - ADC that would work
for your application, and interface to the Basic Stamp.
Have a look at the datasheet:
http://dbserv.maxim-ic.com/quick_view2.cfm?pdf_num=1070
Bruce
webmaster@r...
http://www.rentron.com
Original Message
To: <basicstamps@egroups.com>
Sent: Saturday, August 12, 2000 2:31 PM
Subject: [noparse][[/noparse]basicstamps] Instrument Development
| Sincerely,
| Dave
Wow, this seems like alot of moving parts just to display values. Can you
use a digital display (LED or LCD) to display the values? This would be
easier, more accurate and more reliable. There are numerous
easy-to-interface (serial) display options available. You could read the
analog values with a MAX186, do a little math and then send a scaled
reading to a digital readout...
Again, any moving parts are going to potentially suffer more than a sealed
digital display.
Best, Duncan
