Problem with pinX command w/ II & 2SX
I am new to this list, so please excuse any redundancy in this question. I
tried emailing Parallax's STAMP support but the email will not go through... (?)
I am trying out a very simple program that will light a LED when a toggle
switch is in a given position. The program is as follows:
again:
if pin0=1 then beginning
if pin0=1 then ending
beginning:
high 7
pause 250
goto again
ending:
low 7
pause 1000
goto again
The problem is that whenever I try to download the program to the 2SX chip or II
chip (using the correct software) I get a "pin0 is undefined" error. I have
tried using caps, spaces, etc. to see whether it was a syntax problem and have
not gotten anywhere. This program is almost straight out of a learning book I
am working with and nowhere does it say whether I have to define "pin0" or why I
might be getting an error. The wiring is as follows:
p0 => Vdd -> 1k resistor -> toggle switch -> p0
p7 => Vdd -> 1k resistor -> LED -> p7
I can get the program to work without the if...then statement involving checking
the state of p0. Hmmm... What am I doing wrong??? Any help would be much
appreciated.
SNF
again:
beginning:
high 7
pause 250
goto again
ending:
low 7
pause 1000
goto again
appreciated.
SNF
pinX is for the Stamp I. For the II and IISX you need to use inX and outX.
again:
if in1=1 then beginning
Or even:
if in1 then beginning
However, I'm not clear on your two if statements
They test the same thing which means the second one will very likely never
execute unless it sees an edge between the two statements.
I'm thinking:
top:
if in0 then offled
high 7
goto top
offled:
low 7
goto top
or even:
OUTPUT 7
again:
out7=in0
goto again
Something like that? Notice that HIGH and LOW implicitly call OUTPUT but if
you are using outX, you have to use an OUTPUT statement.
Good luck!
Al Williams
AWC
*Basic Stamp FAQ: http://www.al-williams.com/wd5gnr/stampfaq.htm
Original Message
> From: SNFettig Listserv [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AkoMrE9eZfTLHxW-aMvNgp0cyc4GAWp6PYZsjFWybKTwbN3zv7GJY2oG1gjGM0hXpKuImM5rtgBDWiyReX4o]lists@s...[/url
> Sent: Friday, July 21, 2000 11:25 AM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Problem with pinX command w/ II & 2SX
> this question. I tried emailing Parallax's STAMP support but the
> when a toggle switch is in a given position. The program is as follows:
> again:
> beginning:
> high 7
> pause 250
> goto again
> ending:
> low 7
> pause 1000
> goto again
> 2SX chip or II chip (using the correct software) I get a "pin0 is
> undefined" error. I have tried using caps, spaces, etc. to see
> whether it was a syntax problem and have not gotten anywhere.
> This program is almost straight out of a learning book I am
> "pin0" or why I might be getting an error. The wiring is as follows:
> involving checking the state of p0. Hmmm... What am I doing
> wrong??? Any help would be much appreciated.
> Regards,
> SNF
Your first statement "if IN0=1 then beginning" will not let program execution
fall-through to
the second statement "if IN0=1 then ending", (unless IN0 = 0).
Why..? If IN0 = 1 program execution is sent to beginning. If IN0=0 you will
fall-through
to beginning because you didn't test to see if IN0=0 and jump to ending.
again:
if IN0=1 then beginning <--- if IN0 = 1 you will never get to the second
line.
if IN0=1 then ending <--- if IN0 = 0 would take you to ending:
beginning:
high 7
pause 250
goto again
ending:
low 7
pause 1000
goto again
The IF IN0 THEN is a logical operation that will test the logic state of the
input
pin. Test
the input pin for each logic value ie,, 0 or 1 to make a decision based on the
state
of the
input.
Example:
again:
if IN0=0 then ending
beginning:
high 7
pause 250
goto again
ending:
low 7
pause 1000
goto again
This should get you there......[noparse]:o[/noparse]]
Bruce
http://www.rentron.com
Original Message
To: <basicstamps@egroups.com>
Sent: Friday, July 21, 2000 10:25 AM
I
| again:
| beginning:
| high 7
| pause 250
| goto again
| ending:
| low 7
| pause 1000
| goto again
II
tried
using caps, spaces, etc. to see whether it was a syntax problem and have not
gotten
anywhere. This program is almost straight out of a learning book I am working
with
and nowhere does it say whether I have to define "pin0" or why I might be
getting an
checking
appreciated.
| Regards,
| SNF
