Is my new BS2SX DOA -or- using wrong editor?
Hi Jay,
Before you ask, here is some useful informations about baudrates.
The BS2SX doesn't work with the values you can find into the manual...
Here is the message I got few days ago :
> The BS2-SX uses different baudmode values with the Serout instruction
> than the original BS2:
> Change $4054 to $40F0 (for 9600 bps)
> -or-
> Change $418D to $43FD (for 2400 bps)
> Depending on the program you're trying to run, the baudmodes will
> either be in a constant definition (like "N9600 CON $4054") or used
> directly in a Serout instruction.
Hope this will help you with your first SX !
Bye,
Phil.
Philippe Derenne
Computer Solutions
mailto:derennep@s...
Original Message
To: <basicstamps@egroups.com>
Sent: Wednesday, July 19, 2000 9:21 AM
Subject: Re: [noparse][[/noparse]basicstamps] Is my new BS2SX DOA -or- using wrong editor?
> -or-
Bye,
Phil.
Philippe Derenne
Computer Solutions
Original Message
>Greetings,
> Just bought my first BS2SX and am a bit puzzled. I've used a number of
>BS2's and the STAMP2X.EXE editor (under DOS 5.0) and had absolutely no
>problems. However, the brand new BS2SX fails to respond to the Alt-I
>command with "Hardware Not Found"....
> This leads me to believe that the STAMP2X.EXE editor does not support
>the BS2SX. Am I correct in this assumption? Do I now *have* to use the
>WinSlut-9x version of the editor to do my work now? Suggestions?
There WAS a DOS version of the Stamp2 SX software. It was short-lived, and
a predecessor to the present "WinSlut" version. I HAD a copy of it, but I'm
not sure if I kept it. You might look at the Parallax website for a DOS
version of the Stamp II SX software.
If there is none, please contact me offlist, and I'll see if I have an
archived copy. I'd check, but I'm in the process of an hour-long download
at the moment (sorry).
> Or is my BS2SX simply DOA?
Probably not. What OPSYS are you using ?
> Thanks,
> --- Jay
Bruce
> | Jay Nugent jjn@n... |____|
> | Nugent Telecommunications www.nuge.com |
> | Web-Pegasus www.webpegasus.com |
> | (734)971-1076 (734)971-4529 /Fax |
> | ISP & Modem Performance Monitoring Svcs. |
> | Discount Reseller of 123.Net ISP Services|
> | Internet Consulting / Linux SysAdmin |
> | Web Hosting / DNS Hosting / Shell Accts. |
> | Embedded Controllers / Engr. & Design |
> \_________________________________________\__/
> 1:00am up 69 days, 6:53, 6 users, load average: 0.07, 0.10, 0.09
--- Jay
On Wed, 19 Jul 2000, Bruce Bates wrote:
> At 01:47 AM 7/19/00, you wrote:
> >Greetings,
Found it! I guess I was assuming that the older version of STAMP2
would at least talk to the BS2SX. Guess I was wrong...
Went back to the Parallax site and found what I was looking for in the
"Download" area. I pulled down STAMP2SX.EXE and it works GREAT! :-) I
also pulled down the STAMPW.EXE install program for WinSlut, just in case
I ever have to use it...
Anyone ever run STAMP2SX.EXE under DOSEMU in Linux?
--- Jay
3:00am up 69 days, 8:53, 6 users, load average: 0.05, 0.08, 0.08
Hi Jay,
STAMP2X.EXE was written expressly to run on Macs. The "x" has nothing to
do with the "x" in BS2SX. Do I surmise correctly that you are running
STAMP2X.EXE under the SoftPC emulator on a Mac? The bad news is that
STAMP2X.EXE won't recognize the BS2SX, and the regular DOS software
(stamp2.exe, stamp2sx.exe) doesn't work for the RUN step on the Mac either.
I don't think Parallax supports stamp2x.exe any more, because it was
problematic on more recent Macs and under the more recent PC emulators.
Visit the Parallax home page
http://www.parallaxinc.com/
for some late breaking news on programming stamps using the Windoze
software running under virtual PC on an iMac--requires some very specific
hardware/software.
Ahh, I see you posted a success! message...
Oh, I guess I was wrong about the Mac surmise...
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
