digital pot?
Dave-
You're trying to stuff 128 pounds of bits into a 16 pound bag. A
"nib" (0.5 bytes, four bits, %0000 through %1111) can assume a value
from 0 through 15, and won't work in your
FOR dataword = 0 TO 127
statement. Change dataword to a byte or change your FOR statement.
Steve
On 14 Jul 00 at 2:46, dave@d... wrote:
> Hey all-
> I'm sure the answer is easy, but this one is stumping me.
> I have an Analog Devices AD7376 that I'm using as a digital
> potentiometer. It's a real simple device that takes 7 bits in via a
> SPI compliant serial bus and sets it's internal wiper to 1 of 128
> positions (0-127, 50K ohms FS).
> However, it doesn't seem to want to play nice with me. The data
> sheet (http://www.analog.com/pdf/2111_01.pdf) isn't very specific
> WRT the interface standard (which bit goes first, clock tolerances,
> everything else I need)
> The setup:
> SDI to pin 15
> CK to pin 14
> /CS to pin 13
> Split supply for the AD7376, common ground (same protoboard),
> bypassing, battery powered, et al.
> I'm using the following:
> 'this is program to test the Analog Devices AD7376An 50K digital
> pot 'c2000 dave paton 'pin 15 is data out, 14 is shiftout clock, 13
> is chip select 'A to +5V, B to GND, W to meter
> dataword var nib
> high 13 'make sure chip is deselected
> testpot:
> dataword = 0
> for dataword = 0 to 127 'loop to go from 0 to 5V
> low 13 'select the chip
> pause 1 'let it catch up
> shiftout 15,14,0,[noparse][[/noparse]dataword\7] 'send the data
> high 13 'deselect chip
> pause 10 'wait for a bit
> next 'go from 0 to 127
> goto testpot 'lather, rinse, repeat forever
> but with the pot connected as a voltage divider for 0-5V, all it
> does is bounce between 1.44 and 1.86V. It should be going from 0 to
> 5. and repeating. I've tried changing the bit order (LSB or MSB
> first), messing with the timing, et al. I can see the waveform on my
> scope, bu due to trigger issues it has I can only grab the last byte
> or so. I know the data is getting there. I'm a C guy by default, and
> tho PBASIC is simple, it sems far from easy.
> I know it's something simple. Any ideas?
> -dave
> Next week's topic: Faster gardening through dynamite
> - dave paton http://www.dpaton.net dave at ieee dot
> org
Steve
> Hey all-
> The setup:
> SDI to pin 15
> CK to pin 14
> /CS to pin 13
> dataword var nib
> testpot:
> dataword = 0
> -dave
> org
potentiometer. It's a real simple device that takes 7 bits in via a SPI
compliant serial bus and sets it's internal wiper to 1 of 128 positions
However, it doesn't seem to want to play nice with me. The data sheet
(http://www.analog.com/pdf/2111_01.pdf) isn't very specific WRT the
interface standard (which bit goes first, clock tolerances, everything
else I need)
The setup:
SDI to pin 15
CK to pin 14
/CS to pin 13
'this is program to test the Analog Devices AD7376An 50K digital pot
'©2000 dave paton
'pin 15 is data out, 14 is shiftout clock, 13 is chip select
dataword var nib
testpot:
dataword = 0
but with the pot connected as a voltage divider for 0-5V, all it does
is bounce between 1.44 and 1.86V. It should be going from 0 to 5. and
repeating. I've tried changing the bit order (LSB or MSB first),
messing with the timing, et al. I can see the waveform on my scope, bu
due to trigger issues it has I can only grab the last byte or so. I
know the data is getting there. I'm a C guy by default, and tho PBASIC
-dave
dave paton http://www.dpaton.net dave at ieee dot org
it gives a working example to your question.
ive attached it, its a pdf file.
Norm & Monda
Cozy MK IV #202
Ford V-6 Powered
Original Message
To: <basicstamps@egroups.com>
Sent: Thursday, July 13, 2000 10:46 PM
Subject: [noparse][[/noparse]basicstamps] digital pot?
Hey all-
else I need)
The setup:
SDI to pin 15
CK to pin 14
/CS to pin 13
'©2000 dave paton
dataword var nib
testpot:
dataword = 0
-dave
See what happens when you code at 1am?
Now, on to bigger and better things....
Rotary encoders. This is to be part of my accellerated senior project
(one year of classes in one semester).
I'm building a digital preamp (I knw, it's been done, so what) and I'd
like to use a rotary encoder for the volume control. Scott Edwards
intrfaced one to a stamp 1 a long time ago, IIRC. I was curious if
someone has:
a. done this with a BS2
and
b. can explain to me how one generates the direction bit from the 2 pin
output of the encoder.
More to come...
-dave
its attached.
Norm & Monda
Cozy MK IV #202
Ford V-6 Powered
Original Message
Sent: Friday, July 14, 2000 6:14 PM
Subject: [noparse][[/noparse]basicstamps] Re: digital pot?
> someone has:
> and
> More to come...
> -dave
