which io pin change state first ?
I have a problem in Bs2 application,
Q1: There are 8 input to BS2, normally these 8 pin is LOW state, but my
application is to determine
which pin occur to "high" state first . Does anyone help me out ?
Baker
Baker
status var byte
hpin var nib
none:
status = inl ' read P0-P7 (use inh for P8-P15)
if status=0 then none ' not yet
' ok now, one or more pins are high, give priority to P0
for hpin=0 to 7
if (status & (1<<hpin))=1 then found
next
found:
' hbin now has pin # from 0 to 7 in it
' if more than one pin is high, the lowest one "wins"
Something like that?
Al Williams
AWC
* 8 channels of PWM: http://www.al-williams.com/awce/pak5.htm
Original Message
> From: baker_bai@c... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wca7pf7fedVAaZ7ta9uSJjlcHHlmL8mHgc0l6fUNr00MDvGHxe7gCjRQE5KJylVob-Jkz_DtOO9rvGyPKzf5]baker_bai@c...[/urlOn Behalf Of
> baker_bai@c...
> Sent: Thursday, July 13, 2000 9:04 AM
> To: basicstamps@Egroups.com
> Subject: [noparse][[/noparse]basicstamps] which io pin change state first ?
> but my application is to determine
> Baker
> Baker
you can read all 8 pins into a byte variable in one command.. then check if
that byte is zero, if not, then check to find which particular bit is high.
if the byte is zero, then read it again (until something goes high)
Jason
> state, but my application is to determine which pin occur
Al suggested:
> status var byte
> hpin var nib
> none:
> for hpin=0 to 7
> next
> found:
Or replace the for-next loop between the
with the single statement,
hbin = NCD status
The NCD function returns the number of the highest bit set in status. It is
a value from 1 to 8, and NCD 0 = 0. So if status=%00100000 going in, then
hbin=6 going out. The routine might be crunched down further to:
hpin var nib
none:
hbin = NCD inL ' read P0-P7 (use inh for P8-P15)
if hbin=0 then none ' not yet
found:
' hbin now has pin # from 1 to 8 in it
' if more than one pin is high, the highest one "wins"
It is a stamper habit, looking for ways to save bytes and clock cycles!
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
> hbin = NCD status
> status. It is
Good point Tracy. Of course, with NCD P7 has priority and you have no
alternative. With the loop you can make either side have the priority. In
fact, to be fair, you could randomly pick which end you started at so that
one input was not consistently favored over another. Also, you can't
determine if more than one is on if you need that information.
Actually, my code is wrong anyway.
(status & (1<<hpin)) will only equal 1 for P0. It should read:
if (status & (1<<hpin))<>0 then found
Oh well!
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> the priority.
no problem, still no loop necessary:
hbin = NCD (status rev 8)
lets the low bit have the highest priority.
> In fact, to be fair, you could randomly pick which end.
> you started at so that one input was not consistently
> favored over another. Also, you can't determine if more
We'd better not get too deep into it without more detail!
The question was simply,
>>> my application is to determine which pin occur to "high" state first.
One application we had fun with here in the past was a game show, where 8
contestants were each to have a button, and a lamp on their stand. The
Stamp was to determine which contestant pressed his or her button fastest
in response to a question, and to show first second and third place by the
rate of flashing of the lamps, and to allow the possibility of ties in each
place. I think I was able to get that down to four or five lines of code,
as a state machine with only one loop and no IFs.
http://www.emesystems.com/BS2misc.htm#Game show
-- Tracy
That's a good one. I had thought of NCD, but I hadn't thought of that one.
Al Williams
AWC
