7805?
I noticed in the boe-bot docs from parallax that they replace the old standby
7805 for a different 5v regulator..
Is there any reason why I couldn't still use one if I separate the power to the
stamp and to the servos?
Sean
Sean
richard
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, June 27, 2000 12:26 PM
Subject: [noparse][[/noparse]basicstamps] 7805?
standby 7805 for a different 5v regulator..
to the stamp and to the servos?
> Thanks
> Sean
drop out) variety. The original BOE used a 9V battery. The 7805 needs
something like 7V+ to give 5V out. The BOE bot uses 4AA cells 4x1.5 = 6V.
This isn't enough to reliably drive the 7805 and even less if the batteries
weaken. The LDO part only needs a hair more than 5V.
Al Williams
AWC
* Pulse input and output with the PAK-VII and PAK-VIII...
http://www.al-williams.com/awce
Original Message
> From: Sean Conlon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XqDoh3vEC9-e0nyJpEpAL5DUkbwdfGJzSaU-T3UtutCnO3LjEYPsyROyGzSCy45_NydFoo1jbZ5xFi8rrO50bP4]gnomish1@p...[/url
> To: basicstamps@egroups.com
> old standby 7805 for a different 5v regulator..
> the power to the stamp and to the servos?
> Thanks
> Sean
