h bridge control
Can anyone suggest a simple h bridge design?
Can the job be accomplished with 4 transistors and some protection diodes??
I don't have much experience with transitors and am worried about having to
find the right resistor values to bias them.
Also, where should any caps go to minimize trans. voltages???
I only want to control 2 dc motor gearboxes.. I believe they are rated at 3
volts and about 0.9 amps.
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
believe in the April & May 2000 issues.)
Also, someone on this list suggested http://www.cadvision.com/blanchas. It
had some informative discussions using Mosfets for H-bridges.
Good luck,
Ray McArthur
diodes??
to
3
diodes??
having to
rated at 3
> volts and about 0.9 amps.\
You might want to look at some of the ICs that are available to do
this function. Two that I have used are the TI 754410(1 amp max) and
the Allegro UDN2998W (2amps max). These are both dual bridges. Your
current requirements are probably a little high for the 754410 and it
can't be heat-sinked very well since it's a DIP, but the Allegro part
is (sort of) a dual TO220 and can be readily attached to a heat sink.
Both include protection diodes. You can use direction control and PWM
speed control with them if desired. There are a number of other
similar ICs available also.
Chuck Davis
Oak Tree Systems
> diodes?? I don't have much experience with transitors and am worried
> about having to find the right resistor values to bias them. Also, where
> 3 volts and about 0.9 amps.
You can roll your own, but there are several complete H-Bridge
chips available that are so convenient and inexpensive that -unless
you're really in it for the educational challenge- it really isn't worth
bothering with a discrete design. The L298 is just such a chip. You
can get just the chip $8 CAD ($5 US), or we have a complete kit
(PCB, all parts) for under $25 CAD (about $16 US). You can see
details and get a datasheet at:
http://www.hvwtech.com/robotics.htm
Mark Hillier
President, HVW Technologies Inc.
Mark@H...
Tel[noparse]:([/noparse]403)730-8603 Fax[noparse]:([/noparse]403)730-8903
Visit our web site: http://www.hvwtech.com
Enter the BEAM/WCRG Millennium Robot Games: http://www.robotgames.com
Al Williams
AWC
* 8 channels of PWM: http://www.al-williams.com/awce/pak5.htm
Original Message
> From: Jason P [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MBHTNYDmiOKq0t8Ynpq-nboFpzWnpZrGM0-nk9XEJe3ZlDH4YuA43Gf8g_QdVPGXGEi2EEwJ7_oOn9d2hw]gish_jp@h...[/url
> Sent: Monday, June 26, 2000 9:55 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] h bridge control
> protection diodes??
> having to
> rated at 3
> Thanks
You'll find several H-Bridge examples in our EDE1204 datasheet - some using
NPN & PNP, and even one that uses only NPN. It's available for download in
the 'Integrated Circuits' section at http://www.elabinc.com
Todd Peterson
E-Lab Digital Engineering, Inc.
www.elabinc.com
diodes??
to
3
http://www.bobblick.com/bob/projects/hbridge/index.html
mistakes. And, Bob is a big help if you have trouble. Guess you'd need one
for each motor though.
http://bobblick.com/bob/projects/hbridge/index.html
Greg
Original Message
To: <basicstamps@egroups.com>
Sent: Monday, June 26, 2000 7:54 PM
diodes??
to
3
> Thanks
