Variable Comparison
Hi all!!! I'm using RCtime to scan 9 CdS cells, reporting the results to 9
different variables. I need to compare these 9 variables, find the largest
value, and then branch to the variables associated subroutine. I could
probably do this by comparing the variables, 2 at a time, but this would take
up to much program space, and I need to cycle through the entire program as
fast as possible...
e.g.. If var1 > (var2, var3, var4, var5, var6, var7, var8, var9), then goto
instruction_for_var1
I have not done a lot of programming, so I was not sure how to do this... ANY
help (ideas, source code, etc.) will be greatly appreciated!!!
Thanks in advance,
Edward Kindler
fast as possible...
Thanks in advance,
Edward Kindler
i var nib
cds var word(9)
cdsmax var word
' fill in array
cdsmax=cds(0) ' guess
for i=1 to 8
if cdsmax>=cds(i) then comploop
cdsmax=cds(i)
comploop:
next
' now cdsmax has the highest value
You do have to be careful about signed numbers (e.g., $FFFF is -1).
Al Williams
AWC
*Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: RiffRaff82@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Q1Xwy10GkmRux9KKbCUHdPTf1bLz9DEXWEVxaQe3nsr-2-sc82MP8e8VAFg2W-qPrziwFHp4rAw89Q]RiffRaff82@a...[/url
> Sent: Wednesday, June 14, 2000 12:35 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Variable Comparison
> results to 9
> the largest
> this would take
> program as
> fast as possible...
> then goto
> this... ANY
> Thanks in advance,
> Edward Kindler
"eye" in "eye(i)" (originally "cds" in "cds(i)" given in Al's response to my
first question) was an unknown variable, so I added "eye var word" to the
var. list... Is this correct??? here is my program so far...
eye var word
eye1 var word
eye2 var word
eye3 var word
eye4 var word
eye5 var word
eye6 var word
eye7 var word
eye8 var word
eye9 var word
i var nib
eyemax var word
Scan:
RCtime 0, 1, eye1
RCtime 1, 1, eye2
RCtime 2, 1, eye3
RCtime 3, 1, eye4
RCtime 4, 1, eye5
RCtime 5, 1, eye6
RCtime 6, 1, eye7
RCtime 7, 1, eye8
RCtime 8, 1, eye9
eyemax = eye1
for i = 1 to 8
if eyemax >= eye(i) then comploop
eyemax = eye(i)
goto scan
comploop:
next
Thanks in Advance,
Edward Kindler
Declare:
eye var word(9)
This will, in effect, do this:
eye(0) var word
eye(1) var word
eye(8) var word
That isn't legal syntax, mind you -- but it is the idea. You only need the
one line.
So everywhere you have eye1 you really need eye(0), etc.
You can make aliases if you like, but it really isn't necessary:
eye1 var eye(0)
eye2 var eye(1)
That leaves your loop:
> eyemax = eye1
> for i = 1 to 8
> eyemax = eye(i)
> goto scan
> comploop:
> next
Don't put the goto scan here.... the entire loop must run to find out which
is largest:
eyemax=eye(0)
for i=1 to 8
if eyemax>=eye(i) then comploop
eyemax=eye(i)
comploop:
next
' now eyemax is the biggest one
' do what you like
goto scan
Gee eye(i) -- sounds nautical.
Al Williams
AWC
*8 channels of pulse output for servos, PWM, etc.:
http://www.al-williams.com/awce/pak8.htm
>RCtime 0, 1, eye1
>RCtime 1, 1, eye2
>RCtime 2, 1, eye3
>RCtime 3, 1, eye4
>RCtime 4, 1, eye5
>RCtime 5, 1, eye6
>RCtime 6, 1, eye7
>RCtime 7, 1, eye8
>RCtime 8, 1, eye9
>eyemax=eye(0)
>for i=1 to 8
> eyemax=eye(i)
>comploop:
>next
>' do what you like
>goto scan
The following loops will run faster, using the stamp's builtin comparison
operator: (And yes, you have to use the MIN operator to find the maximum
value!)
eye var word(8)
i var nib
eyemax var word
Scan:
for i=0 to 8
RCtime i, 1, eye(i)
next
eyemax=0
comploop:
for i=0 to 8
eyemax=eye(i) min eyemax
next
' do what you like
goto scan
or combine the loops for more speed, less code:
Scan:
eyemax=0
for i=0 to 8
RCtime i, 1, eye(i)
next
' do what you like
goto scan
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
That's a good idea -- I always find it odd that min gives you max and max
give you min. Yes, I know why -- but it still strikes me as odd.
I thought about the loop combo, but sometimes that really give you less
speed! For example, a while back I did an IR project that was a SOM project
(in fact, the same code was a small part of a robotics article I did using
BoeBot). To read the IR, you had to get like 14 bits read in a row (PULSIN).
However if you did it in a loop, the loop overhead was more than the
execution overhead, so you missed some bits. So instead of:
For i=0 to 13
Pulsin .... x(i)....
next
it was actually faster to use:
Pulsin ....x(0)....
Pulsin ....x(1).....
etc.
Of course, it takes more EEPROM space.
Anyway, if the time between samples is not very critical, the two loops
would work fine.
Al Williams
AWC
* Expand your Stamp I/O with a PAK-III or PAK-IV:
http://www.al-williams.com/awce/pak3.htm
identified value, consider these additions to Tracy Allen's suggestion:
eye var word(8)
i var nib
eyemax var word
imax var nib
Scan:
for i=0 to 8
RCtime i, 1, eye(i)
next
eyemax=eye(0) 'setting to the first in the array saves one interation
of the for-loop
imax=0
comploop:
for i=1 to 8 'note change in start variable--saves time, but
less clear
if eye(i) <= eyemax then isLess
'new maximum found
'the "less-than-or-equals" biases toward the
'first inspected of several photocell with equal values
'use "less-than" to bias to the last inspected
imax=i
eyemax=eye(i)
isLess:
next
' eyemax contains the largest value of all photocells
' imax identifies the photocell with the largest value
branch imax, [noparse][[/noparse]cds0, cds1, cds2, cds3, cds4, cds5, cds6, cds7, cds8]
branchelse:
'do something if branch did not transfer control
goto scan
cds0:
'do stuff
goto scan
cds1:
'do stuff
goto scan
cds2:
'do stuff
goto scan
cds3:
'do stuff
goto scan
cds4:
'do stuff
goto scan
cds5:
'do stuff
goto scan
cds6:
'do stuff
goto scan
cds7:
'do stuff
goto scan
cds8:
'do stuff
goto scan
Daniel
Original Message
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: 14 June 2000 13:35
9
take
>fast as possible...
ANY
>Thanks in advance,
>Edward Kindler
I know you know, Al, but maybe it is not so clear to others. It is a very
useful, but misunderstood function.
The MIN operator is like what is sometimes called the FLOOR function in
analog computers or simulators or PID controllers. And MAX is more like
the CEILING function.
Y= X min FLOOR ' means Y= X but not less than FLOOR
Y /
| / Y=X
FLOOR|----'
~~~~~~~~~~~~~~~~~~~~X
Then plugging FLOOR in on the left side of the assignment:
FLOOR = X min FLOOR "X but not less than FLOOR
has the effect of raising the floor up to the value of X.
Y /
new | / Y=X
FLOOR|
~~~~~~|~~~~~~~~~~~~~X
new high X
FLOOR ends up being greater than all the values of X. You have to start
with FLOOR=the most minimum value
And
CEILING = X max CEILING
has the effect of dropping the ceiling, so it is less than all the values
of X. You have to start with CEILING=the most maximum value.
In another intuitive view, ( Y = X1 min X2 ) returns whichever is the
lowest value, X1 or X2. But that is not the way the Stamp works. (But
caveat, PICBASIC pro and many other BASICs do implement this other view).
This other view is commutative, that is, (Y = X2 min X1) gives the same
result as (Y = X1 min X2).
The FLOOR and CEITLING functions as the stamp does is are not commutative.
Here is the graph of
Y = FLOOR min X ' means Y= FLOOR unless X is less than FLOOR
Y
FLOOR- ,
| / Y=X
~~~~~|~~~~~~~~~~~~~~X
FLOOR
Which when you think about it turns out to be the same as the CEILING
function
Y = X max CEILING ' means Y = X but not more than CEILING
Y
CEIL - ,
| / Y=X
CIEL
Here is another completely different way to use the min and max functions,
just to illustrate their usefulness. The example is a thermostat that has
to turn on when the temperature exceeds, say, 70 degrees. Instead of using
an IF-THEN statement, the program can control the output directly with a
little math using the min and max operators:
out0 = temperature min 70 - 70 max 1 ' P0 is 1 only when temperature >
70
-- Tracy Allen
I assume that the "max 1" applies to the entire preceding expression because
of the left-to-right evaluation of the Stamp. Is that correct?
Thanks in advance,
Ray McArthur
using
> 70
because
>Thanks in advance,
>Ray McArthur
functions,
>> switches when the temperature exceeds, say, 70 degrees. Instead of
>> using an IF-THEN statement, the program can control the output directly
>> with a little math using the min and max operators:
>> out0=temperature min 70-70 max 1 ' P0 is high when temperature > 70
right, Ray, the max applies to the entire preceding expression in Stampese.
for example, if the temperature=65, then
65 min 70 = 70
65 min 70 - 70 = 0
65 min 70 - 70 max 1 = 0
out0 = 0
but if the temperature =75, then
75 min 70 = 75
75 min 70 - 70 = 5
75 min 70 - 70 max 1 = 1
out0 = 1
I think I made a mis-statement in my last post, that
Y = X min FLOOR
and
Y = FLOOR min X
are not the same thing. (Not commutative). Just to set the record
straight, after considering it a little more, I think they _are_ the same.
Y /
| / Y=X min FLOOR
| / or
| / Y=FLOOR min X
FLOOR|----'
~~~~|~~~~~~~~~~~~~~~X
FLOOR
hmmmm?
Y = X1 min X2 ' Y=X1 if X1>X2; Y=X2 if X1<X2
versus X
Y = X2 min X1 ' Y=X2 if X2>X1; Y=X1 if X2<X1
same inequalities, qed
So what? On the stamp, it is sometimes convenient to switch the order of a
calculation to avoid using parentheses (to save memory and enteries on the
internal calculation stack).
-- Tracy Allen
I didn't check your commutative statement in the first posting. However,
after hurting my head, I agree with your second post [noparse]:)[/noparse]. As you probably
know, PBPro uses min/max differently, which hurts the head again [noparse]:)[/noparse]
Ray McArthur
> Y /
> | / Y=X min FLOOR
> | / or
> | / Y=FLOOR min X
> FLOOR|----'
> FLOOR
> hmmmm?
> versus X
