Cds sensors and Stamp 1
Hope you can help. Ive just discovered the stamp controllers and Im
building my first robot.
Ive got everything working, Servos and switches but want to add some
light detection for light source hunting.
Ive got a couple of Cds sensors from Maplin but cant find an
explanation on how to hook them up to the stamp.
Ive checked all of the documentation and FAQ's but with no success.
I found the Thermistor cuircit in the Stamp PDF document and adapted
that so I have one pin of the Cds to pin0 then a capacitor from the
other pin of the Cds to earth.
I did not have a 0.1uf capacitor but did have a 0.33uf capacitor.
The readings I got back were in the range of 120 - to 255 but
sometimes the reading was 0 if I blocked out all light.
Should I expect to see a range of 0 to 255 from this device if I have
the 0.1uf capacitor ? and where was the reading of 0 coming from when
All Im going to do is compare the values coming back from the devices
and point the robot in the appropriate direction.
Heres the test code:
symbol x = b0
run:
pot 0, 39, x
debug cls,x
pause 15
goto run
I used Alt P to get the range for the ambient light in the room and
came up with 39.
Can anyone give me some pointers or point me to an example ?
Gordon Endersby
symbol x = b0
run:
pot 0, 39, x
debug cls,x
pause 15
goto run
came up with 39.
Gordon Endersby
the Stamp manual about the RC time function. It's has all the necessary
formulas to figure out the reading with different resistors and caps.
-William
Original Message
To: <basicstamps@egroups.com>
Sent: Friday, June 16, 2000 7:11 AM
Subject: [noparse][[/noparse]basicstamps] Cds sensors and Stamp 1
> symbol x = b0
> run:
> pot 0, 39, x
> debug cls,x
> pause 15
> goto run
> came up with 39.
> Thanks
> Gordon Endersby
use the pot command.
I managed to get a 0.1uf capacitor today from maplins and im getting
a much better response from the photo resistors.
So that should sort me out.
Thanks anyway
Gordon
--- In basicstamps@egroups.com, "William Cox" <william@c...> wrote:
> If your using a byte variable the largest value you will get is
255. Read in
necessary
caps.
> -William
Original Message
> From: <gordon.endersby@m...>
Im
some
success.
adapted
the
have
when
devices
> > symbol x = b0
> > run:
> > pot 0, 39, x
> > debug cls,x
> > pause 15
> > goto run
and
> > came up with 39.
> > Thanks
> > Gordon Endersby
