tiny pager motors
anyone know the type of plug
used on the tiny pager vibrator
motors?? What is the name,
who makes it and where can I
get a female side ??
thanks
also, how did you remove the
vibrator weight? -[noparse];)[/noparse]
thanks
> thanks
Grind it off carefully with a Dremel(-like) tool and a small grinding
wheel, or carbide disk (which will slice it) parallel with the shaft.
Bruce
Materials needed.
1 - Thin piece of hard steel.
ahh.. metal putty knife?
1 - Hacksaw (thin blade).
Sorry no substitutes for this
1 - Steel pipe.
ID as needed so motor fits freely inside and twice
as long as the motor. 1/2" 3/8" drive socket?
1 - Drive Punch with VERY small diameter.
Your not likely to find this item so a push pin, the
type with the plastic head will do nicely.
1 - Hammer. Mabey that 3/8" ratchet from the socket set above ;>
A. Use the hacksaw to cut a narrow slot about 1/4" deep into
the an edge of the thin steel plate.
B. Slip the pager motor shaft into the slot in the
steel. (motor on one side weight on the other)
C. Place this assembly with the motor into the pipe.
(You may want to tape the wires of the pager motor
around the body to protect them from getting pinched.)
D. Place pipe on hard surface.
E. Insert sharp end of push pin into hole on end of weight
so it is against the end of the motor shaft.
F. Tap lightly with hammer until motor falls out.
Best of luck..
Original Message
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6qTEzgiusiuUiBEM18ietuLlN1a4Rf375zGbUe76CvF3yYV0VceX6ui6CV_tCFhyWugrYyfDN3ckO9Bmbck]bvbates@u...[/url
Sent: Tuesday, June 15, 1999 8:53 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] [noparse][[/noparse]ot] tiny pager motors
> thanks
Bruce
I think I'll tap it out, maybe a sacrificed-china drill bit #0 will do it as
a punch.
What about that dinky little plug, any leads...
Original Message
From: "Witherspoon, Michael J" <michael.j.witherspoon@i...>
To: <basicstamps@egroups.com>
Sent: Friday, June 16, 2000 10:45 AM
Subject: RE: [noparse][[/noparse]basicstamps] [noparse][[/noparse]ot] tiny pager motors
> Here's my favorite method.
> Materials needed.
> 1 - Steel pipe.
> Best of luck..
> Mike
Original Message
> From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9WFEMTZ-xtn8PTPmAem_ltCPF3SDX0WZMPm9O7oB9pXSa3DiKDcQTzd1gL8ULO5KxLAAL6Cf2fAEU-ZXpn35]bvbates@u...[/url
> > thanks
> Regards,
> Bruce
I clipped two pins from a .1 header and soldered the leads to them.
Original Message
From: rad0 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iDfrmB9fVKjBppKrlgxEq0V25EChvbBoO7JlpU_I8kla0izP1pBqC4WkcbaKzFmLcTh_LQ]rden0@h...[/url
Sent: Friday, June 16, 2000 9:31 AM
thanks,
a punch.
Original Message
> Materials needed.
> 1 - Steel pipe.
> Best of luck..
> Mike
Original Message
> From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3Z0KOC6oxLm5qrKrAnMhPcd9UXfbY1meVghA0iCtcpKaGn0G9mweCiKI7wp6uOUlBXTji1O72hqarzzUSA]bvbates@u...[/url
> > thanks
> Regards,
> Bruce
metal and a hammer to beat the shaft out. Good tutorial on
www.beam-online.com
-William
Original Message
Sent: Friday, June 16, 2000 12:36 AM
Subject: [noparse][[/noparse]basicstamps] [noparse][[/noparse]ot] tiny pager motors
> thanks
to write a short tutorial briefing?
-William
Original Message
From: Witherspoon, Michael J <michael.j.witherspoon@i...>
Sent: Friday, June 16, 2000 11:45 AM
> Materials needed.
> 1 - Steel pipe.
> Best of luck..
> Mike
Original Message
> From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yMbaBibya55iZ04btnNouSSbQu-zYI_Oxnfjc3MeiRoIt027Hlwsg8ZF5TDtbAlM9J80da9FYGFjnBCxOtw]bvbates@u...[/url
> > thanks
> Regards,
> Bruce
