Binary Numbers to Decimals
Hello everyone I'm trying to figure out how to convert decimals to
binary numnbers, binary to hexadecimal, and decimal to hexdecimal
Is there an equation I can use to convert this. Please help.
2**3 2**2 2**1 2**0
(2**3 means 2 to the third power)
So say you have 10 decimal. Start at the left, 2**3 = 8. 8<=10 so set that
bit to 1. 10-8 is 2, so you have 2 left.
Next is 2**2 = 4. 4>2 so set that bit to 0.
2**1 is 2 and 2<=2 so set this bit to 1 and subtract. 2-2 = 0 so you are
done.
1010
Going the opposite way is to just add the bits.
0111
2**2 + 2**1 + 2**0 = 4+2+1 = 7
Hex is easy because every 4 bits is one hex digit.
0=0000 1=0001 2=0010 3=0011 4=0100 5=0101 6=0110 7=0111
8=1000 9=1001 A=1010 B=1011 C=1100 D=1101 E=1110 F=1111
10100111 = 1010 0111 = A7
39 = 0011 1001
You can convert between hex and decimal by going to binary and then to
decimal. Or...
Convert each digit to 0 to 15 and multiply by 16**n where n is the position.
So 64 hex is 6 * 16**1 + 4 * 16**0 = 6 * 16 + 4 * 1 = 96 + 4 = 100
20F0 is 2 * 16**3 + 0 * 16**2 + 15 * 16**1 + 0 * 16**0 = 2 * 4096 + 0 + 15 *
16 + 0 = 8432
Many cheap calculators will do this for you. Also if you start the Windows
calculator and select View | Scientific, you can do conversions that way.
Al Williams
AWC
*8 channels of pulse output: http://www.al-williams.com/awce/pak8.htm
Original Message
> From: reggie19523@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h0H13jGyJdUAL0OMJvisq5dY5QxVu2PPCLdUQc5_9JCKrSZz_wvJmQFLCxj5QYNS0BYd2ZVZMyHvYQKfvQ]reggie19523@y...[/url
> Sent: Wednesday, May 31, 2000 2:24 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Binary Numbers to Decimals
modifiers that will do the work for you
Al Williams wrote:
> Each binary digit represents a power of two. Let's do a 4-bit number:
> 2**3 2**2 2**1 2**0
> done.
> 1010
> 0111
> 39 = 0011 1001
> decimal. Or...
> 16 + 0 = 8432
> Regards,
> Al Williams
> AWC
Original Message
> > From: reggie19523@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qsJ0agy8hOyR6uqtpyE85cX1wbxs8xfi08UKNC0iRQ78GwqMhIGDJ0tf4EUVspXzujow6XimqDeEfbQRpBc]reggie19523@y...[/url
line and you will get the value in all three formats using the debug
screen and a stamp of course.
I wish someone would add this to the stamp software or write a VB
program for doing this and make it easy when programming?? AL ??
w0 =
DEBUG ? W0
debug hex ? w0
debug BIN ? w0
LarryGaminde wrote:
> what are you trying to do display this or read a RTC ? there are
> > 2**3 2**2 2**1 2**0
> > done.
> > 1010
> > 0111
> > 39 = 0011 1001
> > decimal. Or...
> > 16 + 0 = 8432
> > Regards,
> > Al Williams
> > AWC
Original Message
> > > From: reggie19523@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WOB-TiZsD4ui3cRrQ8iQbBHcbswtv5NeUGB8XCbfBvAeb4Bd5NKJ0LiJhU-AaCM-JtcUfcK5k4jkAZbaMQvi8Q]reggie19523@y...[/url
works great!!
LarryGaminde wrote:
> here is something I use just type the hex,bin,dec number on the first
> w0 =
> DEBUG ? W0
> debug hex ? w0
> debug BIN ? w0
> > > 2**3 2**2 2**1 2**0
> > > done.
> > > 1010
> > > 0111
> > > 39 = 0011 1001
> > > decimal. Or...
position.
> > > 16 + 0 = 8432
> > > Regards,
> > > Al Williams
> > > AWC
Original Message
> > > > From: reggie19523@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OlnjNd2lL6qJEu78xWCOjVOjGSP4lLYQyS29MlDeSqUd_rUcMQmFfyQYtvX5LNZfoeCxmyR4sUC5WdCEkG8R]reggie19523@y...[/url
reggie19523@y... writes:
Where are you wanting to do the conversions? You don't need to in the Stamp
since the SEROUT and DEBUG modifiers (BIN, HEX and DEC) take care of things
for you.
needed an example so this is it. Get it at www.al-williams.com/number.exe
Type in either decimal, binary, or hex and it fills in the other two. Copy
and paste if you like. The binary is only good to 16 bits. Probably ought to
do a better job error and range checking. You need the VB runtime. If you
don't have it, download and install the BS1 emulator and you should get all
the files you need.
Really not a very useful program, but I needed an example anyway so....
Enjoy.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: LarryGaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=duWv0B78CXqo2Ze7adsYaafEcXx1NlqMEeOeR_X9xqHDDrDla27YzxVRrDupWHe9gPugivWcr8msA6JL]lgaminde@t...[/url
> Sent: Wednesday, May 31, 2000 3:09 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Binary Numbers to Decimals
> w0 =
> DEBUG ? W0
> debug hex ? w0
> debug BIN ? w0
> > > 2**3 2**2 2**1 2**0
> 8<=10 so set that
> so you are
> > > done.
> > > 1010
> > > 0111
> > > 39 = 0011 1001
> > > decimal. Or...
> is the position.
> 4096 + 0 + 15 *
> > > 16 + 0 = 8432
> start the Windows
> > > Regards,
> > > Al Williams
> > > AWC
Original Message
> > > > From: reggie19523@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o5f87HY5ol-mxywQofc1ujYojnPe6BhJcJ3MPxhh5RbuPCaXASw9Rme2qT8PzcuET6MyN5PQhj9pi0w]reggie19523@y...[/url
also. Works great..... ==Mac==
to know, there are formulas:
Binary/Decimal:
Each binary digit is raised to the next power of 2 when converting
to decimal.
for an 8 digit number:
2^7, 2^6, 2^5, 2^4, 2^3, 2^2, 2^1, 2^0
128, 64, 32, 16, 8, 4, 2, 1 (ok, I think you get the point)
for example:
10100101
1x128 + 0x64 + 1x32 + 0x16 + 0x8 + 1x4 + 0x2 + 1x1 or simply
1x128 + 1x32 + 1x4 + 1x1 = 165
Binary/Hexadecimal:
Each group of 4 binary digits forms one hexadecimal digit
10100101 --or-- 1010 0101
Use the above calculation for binary to decimal to determine its
decimal equivalent, then convert to hex.
1010 = 1x8 + 1x2 = 10 = A
0101 = 1x4 + 1x1 = 5 = 5
Thus, the hexadecimal equivalent of 10100101 is A5.
If you don't believe me (or your own calculations), check it on your
calculator. Of course, by that time, you might as well have done
the whole thing on the calculator and saved yourself some time. [noparse]:)[/noparse]
~JL
The TI-34 calculator ~$19 will do that with ease. I'm sure there are
others
