buffering DAC output
I have a DAC hooked up to stamp to provide me with a variable voltage from 0
to 5 volts. What I need to do is put this through an op-amp to change it to
a proportional voltage from 0-8 volts (or whatever voltage the op-amp is
running at). I need a single supply op-amp to do this, can somebody
recommend one? Now here comes the tricky part, I need to buffer the output
of the op-amp to supply a current of up to 2A peak. My devices (IR LEDS)
will be on for at most 100 msec, at a time. How could I do this? Would an
emitter-follower work? how about a single supply audio op-amp, can they
amplify a DC voltage? I know there are some audio op-amps that supply up to
6A. Could I have the op-amp charge a large capacitor? Help me out here.
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
and probally do part of what you want. Part # 62-5011, Op Amp Book from
Radio Shack might help you out.
Ralph in Fl
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, May 23, 2000 7:56 PM
Subject: [noparse][[/noparse]basicstamps] buffering DAC output
0
to
output
to
Audio power amps like the LM1875 (3A) can definitely handle DC. I've used
them successfully for DC motor drive amplifiers. BUT, the input common mode
range doesn't include ground, and the output doesn't get any closer than
about 2V from either supply rail. You can fix the first problem by
providing a small negative supply voltage, possibly from a little DC/DC
converter module. It doesn't have to handle a lot of current unless you
want to drive the load negative. The second problem can be fixed by
providing a positive supply at least 2V higher than the necessary output
voltage. One more thing... These guys are unstable at gain values below
10x, so you may be compelled to attenuate your DAC output in order to
retain the resolution that you're paying for.
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
0
to
output
to
The LM358 is a popular single supply op amp that should work okay for this.
And yes, an emitter follower is a good bet to increase the power and
current levels. Include the transistor in the feedback loop, something
like this:
12 volts
o
0-4V |\| /
DAC ----| \ |/
| >-/\/-| TO220 NPN
;--| / 47 |> Darlington
| Vss |
;-/\/\-o
/\/\---o---load----Vss
| 10k 10k 0-8 volts
Vss
The emitter follower is a stable and reliable circuit. The supply voltage
has to be at least 4 volts higher than the maximum output level. I don't
recommend the audio op-amp, for the reasons Mike pointed out. I'm not clear
what the IR LEDs will be doing that requires a DAC driver.
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
transistor was controlled via the emitter. What am I missing? Why does the
supply voltage have to be 4v higher? Is it the op-amp? or the transistor?
Could I maybe use a mosfet in some way so as to aviod this overhead voltage?
Maybe I should have pointed this out earlier, but I need to be able to
switch the LED on and off and control the intensity via this varying
voltage. maybe this will help.
o 0-8 volts@2A
_
D__|/
o GND
The D is a serial data input, thats what the switch on and off is all about.
I know the diode is in there backward, ASCII art is kinda hard.
>From: Tracy Allen <emesys@c...>
>Reply-To: basicstamps@egroups.com
>To: "INTERNET:basicstamps@egroups.com" <basicstamps@egroups.com>
>Subject: Re: [noparse][[/noparse]basicstamps] buffering DAC output
>Date: Tue, 23 May 2000 21:41:44 -0400
>from
>0
>to
>output
>an
>to
>like this:
> 12 volts
o
> 0-4V |\| /
> DAC ----| \ |/
> | >-/\/-| TO220 NPN
> | Vss |
> ;-/\/\-o
> | 10k 10k 0-8 volts
> Vss
> -- Tracy Allen
I have been trying to interface the 8254 programmable interval
timer to the Bs2. I am writing an 8 byte word to one of the counters.
I then trigger the counter. I use the latch command to latch the value
of the counter before reading the value of the counter.
However, If I load the counter with a value of 100 when I read back the
count I am getting value like 253 etc.
This device is the heart of my project. As it is responsible for producing a
pulse between 1 and 8ms.
Tracy mentioned that she had interfaced a DAC to the controller.
Could I use a DAC to generate a square wave? The width of pulses
is determined by a dec value between 1 and 255?
Tracy I am interested in the DAc you are using and the code.
00000100
256 - 3 = 253 ??
richard
Original Message
Sent: Wednesday, May 24, 2000 7:45 AM
> Hi Tracy,
a
In Binary 8 bits = 256
In BCD to 2 four Bits = 99
I am using Binary. I am doing the following
OUTH=256
I am assuming the PINS from 15 to 8 will have
11111111 in case of OUTH=100 the Binry value
of 100.
The count seem to be decrementing but the values
are questionable.
>From: "dakota" <rfriedrich@i...>
>Date: Wed, 24 May 2000 07:45:34 -0500
>I haven't been following this thread but could it be you are sending
>binary
>00000100
>256 - 3 = 253 ??
>richard
Original Message
>From: fernando hood <hoodey@h...>
> > Hi Tracy,
>producing
>a
Date: Tue, 23 May 2000 16:56:47 PDT
an
to
In regard to supplying peak current from a capacitor for .1 seconds
without having to have a supply that can put out 2 amps continuously:
You can calculate the supply current by knowing the duty cycle of the
2 amperes. I.e. if you have .1 seconds of 2 amperes every 1 second
then the average current is .1/1 x 2 amps = .2 amps [noparse][[/noparse]ideally - give
it a bit more...].
The capacitor on the supply can be calculated from the allowable voltage
drop on the capacitor during the high current draw.
Q=CxV=IxT : Charge = farads x volts = amps x seconds. Therefrom
C=IT/V. If a 2 volt drop for .1 seconds is allowed with 2 amps then
C=2x.1/2 = .1 FARAD! Capacitors in this range tend to be either very
large or high lacking in high current discharge capability.
A useful alternative to a large capacitor is often a battery which
supplies the short term current pulses.
The emitter follower circuit Tracy provided is a good solution keeping
in mind that the current gain of the current driver transistor must
be high enough to supply the 2 amps with the lower drive current from
the Opamp - say 20 ma. into its base [noparse][[/noparse]i.e. the dc gain of the driver
at 2 amps must be 2/.02 = 100].
Good luck with the project.
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
>>like this:
>> 12 volts
o
>> 0-4V |\| /
>> DAC ----|+\ |/
>> | >-/\/-| TO220 NPN
>> ;--|-/ 47 |> Darlington
>> | Vss |
>> ;-/\/\-o
>> | 10k 10k 0-8 volts
>> Vss
>That's an emitter-follower? I thought that in an emitter-follower the
Hi Ed,
It's an emitter follower, because the voltage at the emitter is always
about 0.6 volt less than the voltage at the base--It "follows" the base.
The voltage gain is unity. But the transistor is capable of supplying lots
of current, much more than op-amp has to supply to the base (=current and
power gain). You may be thinking of an "common emitter" amplifier, in
which the output is taken from the collector circuit, or "common base"
which is the configuration in which the signal is injected to the emitter.
The emitter follower is also known as "common collector". But I think the
terminology gets in the way of understanding how it works. If you want a
good book on the subject, everyone recommends "Art of Electronics" by
Horowitz & Hill.
By designing the transistor into the feedback loop of the op-amp, the
overall voltage gain is controlled very accurately, e.g., 4 volts in->8
volts out. The emitter of the transistor is connected both to the load
(your LEDs) and to the feedback point for the op-amp.
>Why does the
voltage?
There is a voltage drop from base to emitter of the transistor. If you use
a Darlington transistor as suggested (for high current gain) this voltage
drop is ~1.2 volts. Also, the LM358 op-amp will only swing up to within
1.5 volts of the Vdd power supply, up to 10.5 volts maximum on a 12 volt
power supply. Adding the op amp's 1.5 volts to the transistor's 1.2 volts
goves 2.7 volts. So "4 volts" is a conservative margin. So you might be
able to get 8 volts output with a 10.7 volt power supply. There are many
op amps available that will swing all the way up to the positive supply
rail, such as the LMC6482, or the old CA3130. Using one of those would
allow the circuit to swing higher. You could certainly use a power mosfet
in place of the bipolar transistor. Then it is a "source follower" ciruit.
But MOSFETs too have a threshold voltage, and it is usually quite a bit
greater than the 1.2 volts of the bipolar transistor. There are ways to
make it swing all the way to the rail ("lo dropout") , by using a PNP
transistor or a P-channel MOSFET, but those are a little more complicated,
to make them stable performers.
10 volts
o----o
| 1k \ |
0-4V |\| / /
DAC ----|-\ | |<
| >-/\/-o--| PNP
;--|+/ 5k |\ Darlington or
| |/| \ Zetex super-beta
| Vss |
;-/\/\-o
/\/\----o-o---load----Vss
| 10k 10k||0.01uf | 0-8 volts
Vss ===
1000uf |
Vss
That circuit can swing a lot closer to the power supply. It requires an
op-amp capable of swinging all the way to the + rail at the output, and a
big capacitor on the output for stability, because the transistor adds
voltage gain in the feeback loop. (It is a PNP transistor, in common
emitter configurattion.) Note the reversed connections to the (+) and (-)
inputs, because the transistor inverts. This is basically the circuit of a
"low dropout voltage regulator". The big capacitor helps supply pulses of
current to your load, and also is necessary to prevent "ringing" in the
output voltage.
> o 0-8 volts@2A
> _
>D__|/
> o GND
about.
That does help with understanding what you are up to. This additional
control circuit could then go into the ground lead for switching the leds.
BTW, this is a "common emitter" NPN switch circuit.
-- Tracy Allen
