reading incoming serial data greater than 1 byte
Hello, I am having trouble reading incoming serial data greater than
one Byte. I have connected my Stamp 2 to a modem, and am trying to
read the responses it gives when I send a command to it. The commands
are successfully sent using the SerOut command.
The particular command I use should solicit a response in excess of
150 characters that terminates with "OK". What happens is OK comes
back , but the message content is lost. I use
serin p,b[noparse][[/noparse]wait("OK"), serData]
This only gives me nothing or just 1 byte!
Ideally, the entire response would be stored in a string.
Please help, I need to see where I am going wrong!
Thank you
Thank you
The command stores the characters AFTER the WAIT qualifier is received,
not the characters before it.
Bean, thitt@i...
data thereafer as well.
The modem gives me "xzy" at the start of the string, 150 bytes then OK. So,
I used WAIT(xyz), and it will never filled the string.
What do you suggest?
Thank you
SmD
Original Message
From: Bean [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eZd194CSViLjsQ-PjxuVcrAZhJPXmx-5jofM2ReKgw6EjitHQLFm-wpIhLLKtGYkik8-MlUMQaa0]thitt@i...[/url
Sent: Monday, May 22, 2000 5:28 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] reading incoming serial data greater than 1
byte
Bean, thitt@i...
You will not be able to store 150 bytes in the Stamp. There is simply not
enough memory.
Wait("xxx") causes serial input to stall until XXX appears. Anything after
that can be read, but still not 150 bytes worth.
Al Williams
AWC
*Floating point math for that Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: sdye@m... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Pp5clublS71MCllC-sg2nhgqH_pLnLNF1G23CCaaj2yhM-1yJtyU-efzSUPRKRnodoM2cCD0LBq0uw]sdye@m...[/url
> Sent: Monday, May 22, 2000 3:48 PM
> Subject: [noparse][[/noparse]basicstamps] reading incoming serial data greater than 1 byte
> Thank you
I was hoping the stamp had some on-board space for processing data.
OK, is there someway the incoming data can be directly ported out to another
pin in a manner that would ensure all data is not lost- i.e. linking two
pins together software wise?
Thank you
SmD
If I understand what you are saying:
enough memory.
Al Williams
AWC
Original Message
> From: sdye@m... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pCd_c5BPd_UydaYRGtd1sKWmrBYeQZqO-d0UANwGmHWD1wF712Ybj-D7nxbwkkT9EIuynpNG-XWcGSiK]sdye@m...[/url
> Thank you
rs-232 output of a gps receiver although I don't know if you can store that
many bites.
Ralph
Original Message
To: <basicstamps@egroups.com>
Sent: Monday, May 22, 2000 4:47 PM
> Thank you
