3-Questions
I'm trying to control multiple servos from a BS2 and ran across three problems. The servos are the Hitec HS300BB.
1. I was trying to use a voltage regulator to obtain 6+ volts from a 12volt source.· I was using a LM317T with the appropriate resistors in the circuit, according to the package diagram. Connecting the circuit to a meter I read 6.7 volts.· Connecting that circuit to the servo reads 2.7 volts.· For·a novice is this an indication that the servo is drawing more amps than the regulator can handle?· If so what would be a good way to achieve a 6 volt output? The intent is a mobile device running off of one 12 volt source.
2.After giving up on the 6volt problem I went ahead and connected the servo to a 6 volt source and the signal pin to the BS2.· I used a simple program to determine the Pulsout Factor to position the servo:
· For X = 1 to 30
··· pulsout pin#, Value
··· pause 20
return
When I ran the program no matter what Value I entered the servo would rotate in one direction to the extreme position, same direction.
I tried a resistor in the signal line with no difference.· Being an electrical novice what is happening?·
3. Finally I noticed that the servo moved very slowly,· I checked the voltage and it read 6 volts, I tried different servos with the same results.
Any help would be appreciated.
Thanks a bunch.
Brian
· For X = 1 to 30
··· pause 20
return
Thanks a bunch.
Brian
have about 1.5 ms center pulse. To get that with a BS2 you'd say
pulsout pin#,750
Try numbers up in that range. As for your servos running slowly, the speed
is proportional to the amount they have to turn. If it is a long way they
will turn fast, short way they will turn slower. Maybe that's your problem.
-William
Original Message
To: Stamps Forum <basicstamps@egroups.com>
Sent: Saturday, May 20, 2000 6:33 PM
Subject: [noparse][[/noparse]basicstamps] 3-Questions
source. I was using a LM317T with the appropriate resistors in the circuit,
6.7 volts. Connecting that circuit to the servo reads 2.7 volts. For a
regulator can handle? If so what would be a good way to achieve a 6 volt
to a 6 volt source and the signal pin to the BS2. I used a simple program
For X = 1 to 30
pulsout pin#, Value
pause 20
return
I tried a resistor in the signal line with no difference. Being an
3. Finally I noticed that the servo moved very slowly, I checked the
Thanks a bunch.
Brian
problem I have some questions for you.
1. did you modify the servo to run contiuously or is it a stock servo?
2.What values are you using for your Value #?
Now some suggestions
If it is a modified servo make sure that either the 2 resistors you used are
extremely close in actual value. Or make sure that the potentiometer is
exactly centered
The resistor you put in the line should be between Signal and Ground. And
the value should be 10K.
The values for using servos range between 500-1000 having 750 as center. so
if you input 750 as the value to a stock servo you should have it stand
completely still.
The third problem might just be in the software or the resistor. As in the
value you put in might be slightly off so that it would turn slowly to one
direction.
Latez
Seth
diagnosis as well. As far as the second problem, however, I encountered
similar difficulty. It sounds like you're powering the servo and stamp off
separate power supplies, a good idea, but it won't work unless you short
both grounds together. I think that's your problem. Another possibility is
that your "value" is not an appropriate number. Try outputting a 1.5 ms
pulse. What type of BS are you using, because the timing values on each are
different. As far as slow movement, I think that's because in each "for"
statement, you're using X as the increment variable. Counting from 0 to 30
would makes it pause longer at each value. If instead, you programmed:
start:
for x = 1 to 5
pulsout pin#, value#1
pause 20
return
for x = 1 to 5
pulsout pin#, value#2
pause 20
return
goto start
It would move back and forth faster. You can also mess with the pause
statement. The other possibility I can think of is that the load on the
servos is too great.
Hope that helps.
-Erik Granstedt
Original Message
From: Brian & Sandy McMillion [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ARvF1KYSJtlm4c7yYRPXTRHspouDqLDEbdXrtIYXyR-1Ti6yDVlui7-ro-E2fL_4IiCHftOD]brianmcm@w...[/url
Sent: Saturday, May 20, 2000 3:34 PM
To: Stamps Forum
For X = 1 to 30
pulsout pin#, Value
pause 20
return
Thanks a bunch.
Brian
__________________________________________________
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
for the values I tried eveything from 30 to 15000 without luck.
Brian
Original Message
To: <basicstamps@egroups.com>
Sent: Sunday, May 21, 2000 2:33 PM
Subject: RE: [noparse][[/noparse]basicstamps] 3-Questions
> I'm afraid I can't help you much with the first problem, that would be my
off
is
are
30
> start:
> for x = 1 to 5
> pause 20
> return
> for x = 1 to 5
> pause 20
> return
> goto start
> Hope that helps.
> -Erik Granstedt
Original Message
> From: Brian & Sandy McMillion [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ekJESEulVfb7N7IbPBuV-Rs2N7aMgcOlTFUkMefkt3pYdxRPD_lEK-VIxQw36aQqzBmPedAC]brianmcm@w...[/url
> To: Stamps Forum
12volt
circuit,
servo
> For X = 1 to 30
> pulsout pin#, Value
> pause 20
> return
rotate
results.
> Thanks a bunch.
> Brian
> Do You Yahoo!?
> http://im.yahoo.com
had many problems fixed with this simple solution.
-William
Original Message
Sent: Sunday, May 21, 2000 4:30 PM
Subject: Re: [noparse][[/noparse]basicstamps] 3-Questions
> Thanks for the help, I haven't tried connecting the grounds together. As
> Brian
Original Message
> From: Erik Granstedt <erik00h2o@y...>
my
> off
possibility
> is
> are
"for"
> 30
> > start:
> > for x = 1 to 5
> > pause 20
> > return
> > for x = 1 to 5
> > pause 20
> > return
> > goto start
> > Hope that helps.
> > -Erik Granstedt
Original Message
> > From: Brian & Sandy McMillion [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5VU52RttwUUG0KijpKwVjXvasiY9RO2gPMnv3h_710z4Xzmbdr4cVDcFZH_oyDeh6-GzCy_dbg]brianmcm@w...[/url
> > To: Stamps Forum
> 12volt
> circuit,
read
the
volt
> servo
program
> > For X = 1 to 30
> > pulsout pin#, Value
> > pause 20
> > return
> rotate
> results.
> > Thanks a bunch.
> > Brian
> > Do You Yahoo!?
> > http://im.yahoo.com
