Transistors
Hi, just wondering if anyone can give me the easiest solution for reading a
schematic for a transistor.
you have the Collector,base and emitter.
i am only really looking for the emitter, or collector... the schematic has
three lines. and one has an arrow on it, does that represent the collector
or the emitter.
thanks in advance.
Tyson
or the emitter.
thanks in advance.
Tyson
If it points in, PNP.
The base is the one that makes a T instead of a V with the inside line.
Al Williams
AWC
This week only: save up to 70% on PAKs -- details at
http://www.al-williams.com/awce
Original Message
> From: Tyson Stephen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VWfpoBkD7KIar19XXvpw-a2L145wAHHx8KRsQb3DCs7bmatqaHjRJHVzIL2DsMyALcaq5KxiJbipDs0]tysonstephen@h...[/url
> Sent: Friday, May 19, 2000 1:56 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Transistors
> reading a
> schematic has
> or the emitter.
> thanks in advance.
> Tyson
arrow points out, on a PNP (Pointing iN Proudly) the arrow points in.
-William
Original Message
To: <basicstamps@egroups.com>
Sent: Friday, May 19, 2000 2:56 PM
a
has
> or the emitter.
> thanks in advance.
> Tyson
Pointing iN Pointer for PNP and Not Pointing iN pointer for NPN...
Silly, but works for me!
.mark
>From: Joost Luyten[noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1aFBeDUN8-e1qkYo52prMgEtylZZk5S6XMpA6HQ0Exc8DQjUvEk7XiwGHfY28_xIiW8U4Hm7lw]on2bbp@p...[/url
>Sent: Friday, May 19, 2000 2:04 PM
>Subject: Re: [noparse][[/noparse]basicstamps] Transistors
><<File: ATT01656.html>>
>Hi all,
>A rule that I once have learned in school is that you could find the emitter
>by using three letters from the word emitter, namely eMITter.
>MIT is the German word for 'with'.
>MIT an arrow ==> with an arrow ==> emitter
>I think not very often used in the USA, but works fine for me [noparse]:)[/noparse]
>--- Greetings from Joost Luyten, ON2BBP
>email :
>- on2bbp@p...
>- on2bbp@a... (this sends an SMS notification to my mobile phone)
>ICQ : 45143957
>Home :
>Joost Luyten
>Werftsesteenweg 44
>2220 Heist op den Berg
>Belgium
Oorspronkelijk bericht
> Van: Al Williams <alw@a...>
> Aan: basicstamps@egroups.com <basicstamps@egroups.com>
> Datum: vrijdag 19 mei 2000 21:24
> Onderwerp: RE: [noparse][[/noparse]basicstamps] Transistors
> The arrow is the emitter. If it points out, you have an NPN transistor.
> Al Williams
> AWC
A rule that I once have learned in school is that you could find the emitter by using three letters from the word emitter, namely eMITter.
email :
- on2bbp@pi.be
- on2bbp@advalvas.be (this sends an SMS notification to my mobile phone)
ICQ· : 45143957
Home :
Joost Luyten
Werftsesteenweg 44
Belgium
Van: Al Williams <alw@al-williams.com>
Al Williams
AWC
> eMITter.MIT is the German word for 'with'.MIT an arrow ==> with an
> arrow ==> emitterI think not very often used in the USA, but works
hey, that's great! you just made my day
Jason
At 03:50 PM 5/19/00 -0400, you wrote:
>The pin with arrow is always the collector. On a NPN (Not Pointing iN) the
>-William
Original Message
>From: Tyson Stephen <tysonstephen@h...>
>a
>has
>> or the emitter.
>> thanks in advance.
>> Tyson
73 de KG4EXY
your bench? Just funning...... ==Mac==
>-William
Original Message
Sent: Friday, May 19, 2000 12:24 PM
Subject: RE: [noparse][[/noparse]basicstamps] Transistors
> Al Williams
> AWC
Thanks a lot for all of your guys help
on the emitter. The collector is the other end of the 'V' shape, and the
base is the flat piece. If current flows out of the emitter it is an NPN
transistor.
-William
Original Message
Sent: Friday, May 19, 2000 9:42 PM
> SAY WHAT William???? Do you have a lot of burnt up transistors laying on
the
> >-William
