RC Servo Acceleration
Why use a servo to act as your vibratory source? They are geared so much
that you will never get really rapid vibration. I would consider using a
small DC motor with an eccentric weight and control it through a solid state
relay, standard relay, transistor, or mosfet.
Tim
[noparse][[/noparse]Denver, CO]
Original Message
To: Basic Stamps <basicstamps@egroups.com>
Sent: Saturday, May 20, 2000 3:58 PM
Subject: [noparse][[/noparse]basicstamps] RC Servo Acceleration
> Hi Everyone,
> Just wondering if anyone can tell or provide an example of an acceleration
> statement for the BS2. I'm using is a Futaba S-148 servo modified for
> 360-degree rotation. What I'm trying to do is develop a parts sorting bin
> that uses the servo as a vibratory source.
> I've tried without success the VAR and CON statements. Which have met
with
> little success. Any ideas welcome.
> Thanks,
> Lester J. Snoderly
> P.O. Box 751172
> Fairbanks, AK 99775-1172
> Email: lsnoder1@a...
Tim
Original Message
> Hi Everyone,
with
> Thanks,
> Lester J. Snoderly
> P.O. Box 751172
They have part number DCM-154 for $2/each, 17.50 for 10 and $125 for 100.
1.5V with an eccentric weight. Even if you had to use a couple of them....
Al Williams
AWC
*Floating point math for the Stamp, PIC, SX or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: Tim Goldstein [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xr-FEyIix4y1bw-26GJ1NMyt6lpfw3NLqQPuyX5pXCf7v1p7226jJwELPEksOi2xLdWsHtin-bNYtU4i]timg@k...[/url
> Sent: Friday, May 19, 2000 5:47 PM
> To: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] RC Servo Acceleration
> solid state
> Tim
Original Message
> From: Lester J. Snoderly <lsnoder1@a...>
> > Hi Everyone,
> acceleration
> sorting bin
> with
> > Thanks,
> > Lester J. Snoderly
> > P.O. Box 751172
>Hi Everyone,
>I've tried without success the VAR and CON statements. Which have met with
>Thanks,
>Lester J. Snoderly
>P.O. Box 751172
>Lester -
In what way are you using the CON/VAR statements ?
A slow speed (clunk ...... clunk ...... clunk ....) "hammer" could be
simply made with any motor and an appropriate "arm". Running it faster or
slower is generally a matter of controlling the current, voltage,
frequency, or what-have-you of the windings.
An RC servo motor is not particularly suited to anything but pulseout
control, due to the nature of the servo amp within. If you rip out the
electronics, you end up with a highly geared DC motor, which is probably
useless for anything but extreme low speed operation. If you rip the gears
out, you have a simple DC motor with NO GUTS (literally and figuratively)
and have just ruined a perfectly fine device for no reason at all, except
autopsy.
With a stepper motor the windings are controlled by slowly or rapidly
switching the windings on and off in a particular fashion. Uni-directional
control of any stepper is a rather simple matter.
Presuming we both realize the above, and presuming we are using a BS-1,
there is an excellent example in App Note 6 in the Parallax PBASIC Manual.
Using the BS-2 is just a matter of code conversion.
Tracy has always referenced state machines for various forms of control.
I would suspect that is the most code efficient and least cumbersome for
many. I have usually used FOR/Next loops (IF-Then or Branch-On in PBASIC),
but I guess that shows both my age, and my early roots in Fortran <shrug>.
ASICS which can control stepper motors of various type can be found on the
following websites:
ELabs, ST Micro, Philips, Allegro, and many others as well.
If one uses a browser and scans for "Ian Harris" + "stepper motor", there
is an excellent academic discussion of steppers (with simple graphics) on
one of the UK university sites.
Surplus stepper motors can be obtained for around $6.00 from numerous
sources, so why anyone would want to use anything else, when a stepper
motor may be appropriate, is beyond me. Surplus DC motors can be obtained
even cheaper, and pager vibrator motors as Al mentioned are dozens for
dollars when purchased in large quantites. YMMV, IMHO, no flames intended,
of course.
Hope that helps
Bruce
Lester J. Snoderly
P.O. Box 751172
