Cheap PC boards
I have successfully used a few diiferent methods to manufacture simple PC
boards. I am currently designing two boards for my bot, and they are
getting so complex I can't imagine how I could make them myself. They are
double sided and have many VERY close traces and or pads. This is my
problem, If I'm even a little out on lining up my top and bottom sides, the
board will be ruined. If i'm little off on the drilling the board I could
very well ruin it. I also frequently have a problem with some traces not
coming through right(I.E. having cracks in the traces so they don't work).
Are there any places (preferably Canadian places) that will make PC boards
for that don't cost and arm and a leg. I've found a couple places on the
net but they want $100+ for PC boards. I have only two requirements: that
holes(not neccesarily all of them) can be plated through, and that the
boards be made accurate enough not to screw up(although I guess thats a
given). Or is there anyone that can do this? Or would I be better off
trying to do it myself? I seem to recall that I once found a place that
could make them for about $20 US.
I could easily merge my two boards on to one board and then just cut them
apart. That'd probably be WAY cheaper than getting two made.
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
Greg
$90-100 US sounds about right. There's the setup cost, plus the per square
inch cost, plus shipping. I use AP Circuits in Canada (www.apcircuits.com).
You can combine your two boards into one "board" when you create the
gerbers. The way you do this depends on your particular PCB software. The
minimum order from AP Circuits is 2 "boards", meaning you would actually
get 4 boards (2 per panel). You cut them apart yourself. At US$90-100,
that's about $25 per board.
Steve
Steve Roberts: sroberts@s...
That is your best bet - combine as different many boards into one panel as
you can. You then amortize the setup costs over all those boards.
The problem with home made double sided boards is the lack of plated thru
holes. If you were careful with the location of top side solder joints and
vias, you can get a reliable board. The problem is that it takes lots of
practice and experience to learn what works and what does not work in that
regard.
Lining up the negatives for double sided boards is really easy. I take a
scrap piece of board and cut it into a 'L' shape with accurate 90 degree
inside shape. The idea is to nestle the board into corner. I tape both
edges of one negative to the sides of the 'L', flip the whole works over,
then line up the other negative and tape one side of that negative to the
long side of the 'L'. Check and double check the registration.
Clean and sensitize the board. Slip it into the 'L' and put into the
expose frame. I use an expose frame made with clear glass both top and
bottom and a vacuum pump to evacuate the air. I expose one side, flip the
frame without removing vacuum, then expose the other side.
But all this may be far too much effort for you. I tend to use AP Circuits
more and more these days - its a couple of hundred dollars each time but
the boards are perfect. I still keep my in-house process around for the
projects where I can't afford even the two day turnaround that APC gives us
- I can have a prototype etched, drilled, stuffed and undergoing test in
less than 5 hours by keeping it in house. That is going to improve
somewhat shortly - I am playing with a simple and inexpensive CNC drill rig
that Gordon Robineau developed. I'll talk about that more later but it
looks REALLY good!
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 16 years of Engineering Innovation (1984 - 2000)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Another vote for AP Circuits... I use them in all cases except multilayer
(4+ layers) prototypes. They do a wonderful job, quickly, and at an
extremely reasonable price. 10 mil design rules are safe, and you can
combine images to get multiple boards per panel. Just be sure to CHECK your
gerber plots before sending in the order!
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
http://run.to/pcb
I'd also recommend apcircuits.
On Wed, 10 May 2000, Gregory Wagner wrote:
> I have used and recommend AP Circuits <http://www.apcircuits.com/>.
> Greg
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
