2 Digit LED Display
I was wondering what i would need to run a two digit numerical LED
display off of a STAMP II. Basically I want to use it as a type of
error code generator for a robot, so I can externally tell what could
be causing problems without having to sift through the code.
As far as i know, I need an LED display, and some sort of IC to drive
it, but I'd like to know what works best, costs least and where I can
find information and datasheets on how to use them.
Chris
Chris
registers. You use one chip per LED but only 3 BS2 lines even if you add 20
digits!
I like all the flexibility these give you. One thing that I did was to
program it so that all the segments were on the one side and DP on the other.
You will understand once you look at the documentation.
www.phanderson.com has all the info in there stamp section on doing this.
Good Luck
Op
A good way to drive seven segment LED displays from the stamp is with
the MAX7219. This chip will drive up to eight (common cathode) digits and
code is available for stamps. Get the chip at:
http://www.maxim-ic.com
Duncan
multi-7-seg. LED dislay, because I couldn't find it on www.phanderson.com.
Thanx
Seth
fimiliar with using the 74HC595s, but any new information still helps.
-Chris
