Buffer-amplifier chip?
Hello all,
I'm trying to interface a PIC with the parallel port on my
computer and I'm only getting ~3.5v for a 'high'. Can anyone suggest a
buffer-amplifier chip that will take a flaky logic level and turn it into 5v?
Thanks, Duncan
Thanks, Duncan
>Hello all,
>Thanks, Duncan
Duncan -
Is this a laptop ?
Bruce
I don't really have a solution for this, for which I'm sorry Duncan, but I have
a
similar problem with my bs2sx: the pins will only output a tiny 0.5 volts when I
set them high ...
I have been trying rctime in the standard light sensor setup from the manual on
all the pins individually and that works perfectly. But when i write a program
that sequentially sets all pins high for a while and measure the pins directly
with a volt meter I only get 0.5 volts.
For every pin there is a 220 ohm resistor on my board ( I soldered those in
after
I saw it on a picture earlier and since allmost all setups require resistors
between the pin and the external circuitry I thought it would be handy to put
them in as standard ) Maybe I shouldn't have done that?
kind regards,
Sandor
orthner@s... wrote:
> Hello all,
> Thanks, Duncan
directly
Are these 220 ohm resistors going from your output pins to ground? If so,
5000/220 = 22 milliamps, which sounds like too much current to source,
especially if you have several pins set to Hi at the same time. Just an
idea...
Also, a common "cure" is to use "Schmidt triggers" on your outputs
(74xxx14) to get a full TTL Hi.
Steve
Steve Roberts: sroberts@s...
However a 3.5 level is "OK" for TTL.
Kent Dillin
and it worked great. Really cleaned up those flaky signals coming from the
parallel port...
Duncan
> directly
> idea...
Nah. I've connected resistors to pin0..pin15 and beyond the resistors there
is just a bank of "sockets" in which I can plug wires going to whatever
external circuitry. The resistors are only there to protect my pins. Also, I
tested them sequentially which means the there's only 1 pin high at a give
time. I measured the potential between the pin after the resistor and ground
with a volt meter and that read 0.5 volts. I din't hook up anything else on
those pins when measuring.
[noparse][[/noparse]....]
