stupid question #1024
im looking at bs1 application dice.bas. my bs2 doesnt like "if pin7
1 then Roll". How do you read the pin statis on the bs2? Bill
if in7=1 then Roll
Al Williams
AWC
* Expand your Stamp's I/O with a PAK-III or PAK-IV:
http://www.al-williams.com/awce/pak3.htm
Original Message
> From: wtomlinson@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BAavUa-yWWv1HD_NN3FygC38JmZ6FVaTGlRFrAAAc5v2SOpKoFbZNXZh2JikIKJvqSC7MUu3gE3iI7h9mq-s4g]wtomlinson@e...[/url
> Sent: Friday, April 14, 2000 5:40 AM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] stupid question #1024
Some options:
IF IN7 = 1 THEN Roll
IF IN7 THEN Roll
widget_active VAR IN7
IF widget_active THEN Roll
It's helpful to think of the I/O pins as variables which may be
addressed as bits (e.g. IN7), 4-bit nibbles (e.g. INA.LOWNIB), 8-bit
bytes (e.g. INA), or a 16-bit word (INS). As with any other
variable, you can assign an alias, such as widget_active, to refer to
the variable by a useful name of your choice.
The Stamp's true/false determination is based on the principle that a
zero value is false and anything else isn't. So if IN7 is high (1),
it's true for the IF statement's purposes. That's why "IF IN7 THEN
Roll" and "IF widget_active THEN Roll" work.
Steve
> = 1 then Roll". How do you read the pin statis on the bs2? Bill
