2 pin BSC2 to stepper
Hi all:
If anyone has worked with these Airpax stepper motor linear actuators give
me a holler please.
They don't seem to have any significant actuation force. Is the low $9 buck
price a tip off? Guess I answered my own question, but any feed back on this
is welcome. So if you pay big bucks the thing is going to have 1 LBF or so?
Here's my code if anyone is interested:
'ALLEGRO UND2544B TO AIRPAX STEPPER LINEAR 'ACTUATOR A92218 (JAMECO P/N
162587)
'3/31/00 TECHNO_MASAI-M.PLUNKETT
'ADAPTED FROM ALLEGRO UND2544B SPEC SHEET.
'TWO WIRE CONTROL OF STEPPER,
'STEPPER WIRE DIAGRAM TO '2544B
'ORG PIN 8
'BLK PIN 6
'BRN PIN 3
'YEL PIN 1
'SEE ALLEGRO DWG# EP-015 FOR ZENER, ETC ON P3 'OF SPEC SHEET, IT WON'T PRINT
OUT UNLESS YOU '"PRINT AS IMAGE".
DIRS = %0000000000000111
CTR VAR WORD
DELAY VAR WORD
STEPS VAR WORD
COIL1_2 CON 0
COIL3_4 CON 1
DELAY = 2
STEPS = 50
'Retract
FOR CTR = 1 TO STEPS
LOW COIL1_2
HIGH COIL3_4
PAUSE DELAY
LOW COIL1_2
LOW COIL3_4
PAUSE DELAY
HIGH COIL1_2
LOW COIL3_4
PAUSE DELAY
HIGH COIL1_2
HIGH COIL3_4
PAUSE DELAY
NEXT
'EXTEND
HIGH COIL1_2
HIGH COIL3_4
PAUSE DELAY
HIGH COIL1_2
LOW COIL3_4
PAUSE DELAY
LOW COIL1_2
LOW COIL3_4
PAUSE DELAY
LOW COIL1_2
HIGH COIL3_4
PAUSE DELAY
NEXT
END
me a holler please.
162587)
'ORG PIN 8
'BLK PIN 6
'BRN PIN 3
'YEL PIN 1
CTR VAR WORD
DELAY VAR WORD
STEPS VAR WORD
COIL1_2 CON 0
COIL3_4 CON 1
DELAY = 2
STEPS = 50
'Retract
LOW COIL1_2
HIGH COIL3_4
PAUSE DELAY
LOW COIL1_2
LOW COIL3_4
PAUSE DELAY
HIGH COIL1_2
LOW COIL3_4
PAUSE DELAY
HIGH COIL1_2
HIGH COIL3_4
PAUSE DELAY
NEXT
'EXTEND
HIGH COIL1_2
HIGH COIL3_4
PAUSE DELAY
HIGH COIL1_2
LOW COIL3_4
PAUSE DELAY
LOW COIL1_2
LOW COIL3_4
PAUSE DELAY
LOW COIL1_2
HIGH COIL3_4
PAUSE DELAY
NEXT
END
your code. I have used a Slo-Syn stepper and a geared stepper from Airpax.
Mine will not even run with a delay of only 2 ms. In both cases, torque
falls off below ~25 ms. If you look with a scope, you can see that coil
current doesn't have time to decay, (because of inductance), at too high a
stepping rate. In addition, mechanical inertia also eats up torque at high
rates. The max rate depends on the particular stepper, but I will bet that
2 ms is way too fast for your motor. The rate can be boosted somewhat by a
zener in your clamp circuit.
Better late than never?
Ray McArthur
Original Message
To: <basicstamps@egroups.com>
Sent: Saturday, April 01, 2000 10:26 PM
Subject: [noparse][[/noparse]basicstamps] 2 pin BSC2 to stepper
> Hi all:
> me a holler please.
buck
this
so?
> 162587)
> 'ORG PIN 8
> 'BLK PIN 6
> 'BRN PIN 3
> 'YEL PIN 1
PRINT
> CTR VAR WORD
> DELAY VAR WORD
> STEPS VAR WORD
> COIL1_2 CON 0
> COIL3_4 CON 1
> DELAY = 2
> STEPS = 50
> 'Retract
> LOW COIL1_2
> HIGH COIL3_4
> PAUSE DELAY
> LOW COIL1_2
> LOW COIL3_4
> PAUSE DELAY
> HIGH COIL1_2
> LOW COIL3_4
> PAUSE DELAY
> HIGH COIL1_2
> HIGH COIL3_4
> PAUSE DELAY
> NEXT
> 'EXTEND
> HIGH COIL1_2
> HIGH COIL3_4
> PAUSE DELAY
> HIGH COIL1_2
> LOW COIL3_4
> PAUSE DELAY
> LOW COIL1_2
> LOW COIL3_4
> PAUSE DELAY
> LOW COIL1_2
> HIGH COIL3_4
> PAUSE DELAY
> NEXT
> END
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
Guess I haven't hooked up my ol'1202A HP o-scope to it, frankly I don't know
how to interpret a scope reading on a stepper,(more the willing to read
anything you might comment on here) but with the delay set to 2 I get the
best performance i.e. seems to get most force, but it skips steps, at other
delays, say just like 4 or so, or even 30, 35 it skips a lotta steps and
auto reverses at the slightest actuation force, like if I touch the
actuator, it will back right up.
Anyway this thing runs great with the delay set to 2 but I need more
reliability, no skipped steps.
I will look into the Slo Syn stepper.
Also, I had a 15v zener on it, just like the Allegro spec sheet for the
UND2544B.
Thanks, no matter how late, I'm just glad I got your post, there been a
pretty big increase in the number of post recently, though they're all
pretty interesting.
Mark
Original Message
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Tuesday, April 11, 2000 6:34 PM
Subject: Re: [noparse][[/noparse]basicstamps] 2 pin BSC2 to stepper
>Pardon the delayed response, but I just noticed that you have delay=2 in
>Ray McArthur
Original Message
>From: techno_masai <plunkettm@e...>
>> Hi all:
give
>> me a holler please.
>buck
>this
>so?
>> 162587)
>> 'ORG PIN 8
>> 'BLK PIN 6
>> 'BRN PIN 3
>> 'YEL PIN 1
>PRINT
>> CTR VAR WORD
>> DELAY VAR WORD
>> STEPS VAR WORD
>> COIL1_2 CON 0
>> COIL3_4 CON 1
>> DELAY = 2
>> STEPS = 50
>> 'Retract
>> LOW COIL1_2
>> HIGH COIL3_4
>> PAUSE DELAY
>> LOW COIL1_2
>> LOW COIL3_4
>> PAUSE DELAY
>> HIGH COIL1_2
>> LOW COIL3_4
>> PAUSE DELAY
>> HIGH COIL1_2
>> HIGH COIL3_4
>> PAUSE DELAY
>> NEXT
>> 'EXTEND
>> HIGH COIL1_2
>> HIGH COIL3_4
>> PAUSE DELAY
>> HIGH COIL1_2
>> LOW COIL3_4
>> PAUSE DELAY
>> LOW COIL1_2
>> LOW COIL3_4
>> PAUSE DELAY
>> LOW COIL1_2
>> HIGH COIL3_4
>> PAUSE DELAY
>> NEXT
>> END
The behavior you describe is bizarre. Normally, skipped steps occur at
too-high rates. Could you have the coils connected wrong, or an incorrect
step? When my code had errors, the motor was quite erratic. I'll check
your code when we have a chance.
I just looked at the Jameco catalog... they don't give coil resistance.
Did you measure it? The steppers I messed with are rotary units, but yours
simply looks like a rotary stepper with a leadscrew attached, so I would
expect it to be similar in operation. The Airpax products I have seen were
decent quality.
Ray
Original Message
Sent: Wednesday, April 12, 2000 11:08 PM
> Hi Ray:
know
other
> UND2544B.
> pretty interesting.
> Mark
Original Message
> From: rjmca <rjmca@w...>
Airpax.
a
high
that
a
> >Ray McArthur
Original Message
> >> Hi all:
> give
> >> me a holler please.
> >buck
> >this
> >so?
> >> 162587)
> >> 'ORG PIN 8
> >> 'BLK PIN 6
> >> 'BRN PIN 3
> >> 'YEL PIN 1
> >PRINT
> >> CTR VAR WORD
> >> DELAY VAR WORD
> >> STEPS VAR WORD
> >> COIL1_2 CON 0
> >> COIL3_4 CON 1
> >> DELAY = 2
> >> STEPS = 50
> >> 'Retract
> >> LOW COIL1_2
> >> HIGH COIL3_4
> >> PAUSE DELAY
> >> LOW COIL1_2
> >> LOW COIL3_4
> >> PAUSE DELAY
> >> HIGH COIL1_2
> >> LOW COIL3_4
> >> PAUSE DELAY
> >> HIGH COIL1_2
> >> HIGH COIL3_4
> >> PAUSE DELAY
> >> NEXT
> >> 'EXTEND
> >> HIGH COIL1_2
> >> HIGH COIL3_4
> >> PAUSE DELAY
> >> HIGH COIL1_2
> >> LOW COIL3_4
> >> PAUSE DELAY
> >> LOW COIL1_2
> >> LOW COIL3_4
> >> PAUSE DELAY
> >> LOW COIL1_2
> >> HIGH COIL3_4
> >> PAUSE DELAY
> >> NEXT
> >> END
[noparse][[/noparse]Apologies to all for the length of this post, but I felt the
information important to many Stampers - due to the fairly
recent availability of linear actuators in the surplus catalogs,
here in the US]
Mark and Ray:
Sorry for my "delayed" response as well. Either my ISP or the eGroups mail
monster ate my earlier reply to this 'thread' <sigh>.
You might take a look at this reference Mark and confirm a recollection I
have -
[noparse][[/noparse] http://www.thomsonmotors.com/airpax/airpax.htm ] in the center picture
labelled
" Value Added Products - "
" Geared Motors and Digital "
" Linear Actuators "
and take a look at the linear actuator at the bottom of the picture -
center of
the frame. If that is what the Jameco (Airpax) linear actuator looks like,
you
may want to continue with that lead and this note. If so,
The Thomson Industries (Airpax) series numbers are:
K92100 and L92100 and are called "Digital Linear Actuators"
Although there is no document number on the literature I personally have
before me, the title/ref is:
"Product Selection and Engineering Guide", Thomson (Airpax Mechatronics),
Thomson Industries, 7 McKee Place, Port Washington, NY, 11050, USA;
1-203-271-6400; www.thomsonmotors.com
and
WWW: www.thomsonindustries.com (US HQ Corporate Site)
E-Mail: litrequest@t... US Toll-Free 1-800-554-8466
Literature Req. No. 12-01-000-6001 US Fax 1-800-445-0329
or 1-516-883-9039 Int'l
Other E-Mail: GB/Europe info@t... ASIA airpax@t...
It can be obtained by download from that same website noted above
[noparse][[/noparse] www.thomsonmotors.com/airpax ] in the Catalog Section, or apparently by
requesting Literature No. 12-01-000-6001 by e-mail (see refs above);
various torque curves are shown there as well.
Personally, I think this piece of literature is a (device specific) "must
have",
and I obtained mine by Snail Mail - some time ago. Whether it can be
ordered like
that today, I don't know for sure. An inquiry at the website might
determine that.
The reason I view it as a "must have" is from the pov that there is very
little
in the way of documentation on linear actuators (in general), and it has
been my experience that most of the units available (new, surplus,
liquidated, etc) seem
to be (at least similar) to those listed in this Thomson (Airpax) catalog.
There is a more important reason yet - if one looks closely at the
documentation (I can't speak for the download, although I would hope it
would concur), one comes to realization that these must be driven as
UNI-POLAR steppers would be driven. This
ties us back to the original question <whew !>.
The Allegro Chip mentioned is for BI-POLAR Steppers. At this juncture the
best recommendation I could make, would be to hold on to the Allegro chip
for some
future adventure with BI-POLAR steppers, and wander over the the E-Lab site:
[noparse][[/noparse] www.elab.com ] and take a look at their EDE-1200 Uni-Polar Stepper ASIC
Chip.
Why ?
In truth any UNI-POLAR stepper drive chip might do, from scads of
manufacturers.
It would be my guess that some additional torque insight might be required,
however, and the quickest route I know to FIRST-HAND information is via
E-Labs and the Prez. there, Todd Peterson [noparse][[/noparse]EMAIL: "Todd Peterson"
<toddp@e...> ] who is kind
enough to monitor this list.
Perhaps Elabs might take this on as a small documentation side-project
(hint, hint),
at some future date. There is additional information I would be happy to
offer for reference. An Elabs EDE-1200 App Note regarding (Airpax) Linear
Actuators, relative
to microprocessors in general, and the Stamp family in specific would be
MOST welcome by all, I'm sure (least *I* would love to have one <smile>).
The additional specific topic(s) of "torque" + "UN-POLAR" + "EDE-1200" (or
other
chips) might be a topic for a brief E.E. "White Paper" (as are becoming so
popular today on niche subjects <weird !>). YMMV on that one.
The tenative and general conclusions I have reached from what I've read, and
what I've learned thru experimetation - are:
FULL, HALF, and MICRO-STEPPING methods are available from UNI-POLAR drive
chips,
and torque curves will vary accordingly. More than that, gearing may be
required, depending on the application. Actuators aren't generally
appropriate for use in
stepper motor applications, but stepper motors (to an extent) might be used
like
a linear actuator (Acme/ball screw drive and helix shaft). Individual
applications
may vary from that general premise.
Generally SLO SYN (type and brand) motors are expensive (even surplus) but
sometimes they are quite necessary; again, depending on the application.
If the Airpax unit is the one I suspect it is - it is intended for LIGHT
DUTY application ONLY. Low cost, light loads and like factors are
consistant with these Airpax (surplus) units.
Hope that helps.
Bruce
>Hi Ray:
>UND2544B.
>pretty interesting.
>Mark
Original Message
>>Ray McArthur
Original Message
>>> Hi all:
>give
>>> me a holler please.
>>buck
>>this
>>so?
>>> 162587)
>>> 'ORG PIN 8
>>> 'BLK PIN 6
>>> 'BRN PIN 3
>>> 'YEL PIN 1
>>PRINT
>>> CTR VAR WORD
>>> DELAY VAR WORD
>>> STEPS VAR WORD
>>> COIL1_2 CON 0
>>> COIL3_4 CON 1
>>> DELAY = 2
>>> STEPS = 50
>>> 'Retract
>>> LOW COIL1_2
>>> HIGH COIL3_4
>>> PAUSE DELAY
>>> LOW COIL1_2
>>> LOW COIL3_4
>>> PAUSE DELAY
>>> HIGH COIL1_2
>>> LOW COIL3_4
>>> PAUSE DELAY
>>> HIGH COIL1_2
>>> HIGH COIL3_4
>>> PAUSE DELAY
>>> NEXT
>>> 'EXTEND
>>> HIGH COIL1_2
>>> HIGH COIL3_4
>>> PAUSE DELAY
>>> HIGH COIL1_2
>>> LOW COIL3_4
>>> PAUSE DELAY
>>> LOW COIL1_2
>>> LOW COIL3_4
>>> PAUSE DELAY
>>> LOW COIL1_2
>>> HIGH COIL3_4
>>> PAUSE DELAY
>>> NEXT
>>> END
I just looked at your code and may have found a problem. Assuming your
motor color codes follow the Airpax codes shown on page 101 of the V1.9
manual, and the wires are connected as you say in your code comments, the
coil phases are incorrect. They should be:
red & green to positive
yellow to UDN pin 1
orange to pin 3
brown to pin 8
black to pin 6
The code looks OK, except you will get a "glitch" when backing up. You can
greatly abbreviate the code you are using by using LOOKUP as in the stamp
manual, page 43.
Good luck,
Ray McArthur
Original Message
Sent: Thursday, April 13, 2000 12:28 AM
> Mark:
yours
were
> decent quality.
> Ray
Original Message
> > Hi Ray:
> know
the
> other
> > UND2544B.
> > pretty interesting.
> > Mark
Original Message
in
> Airpax.
torque
coil
high
> a
> high
> that
by
> a
> > >Ray McArthur
Original Message
> > >> Hi all:
> > give
> > >> me a holler please.
$9
> > >buck
on
> > >this
> > >so?
P/N
> > >> 162587)
> > >> 'ORG PIN 8
> > >> 'BLK PIN 6
> > >> 'BRN PIN 3
> > >> 'YEL PIN 1
WON'T
> > >PRINT
> > >> CTR VAR WORD
> > >> DELAY VAR WORD
> > >> STEPS VAR WORD
> > >> COIL1_2 CON 0
> > >> COIL3_4 CON 1
> > >> DELAY = 2
> > >> STEPS = 50
> > >> 'Retract
> > >> LOW COIL1_2
> > >> HIGH COIL3_4
> > >> PAUSE DELAY
> > >> LOW COIL1_2
> > >> LOW COIL3_4
> > >> PAUSE DELAY
> > >> HIGH COIL1_2
> > >> LOW COIL3_4
> > >> PAUSE DELAY
> > >> HIGH COIL1_2
> > >> HIGH COIL3_4
> > >> PAUSE DELAY
> > >> NEXT
> > >> 'EXTEND
> > >> HIGH COIL1_2
> > >> HIGH COIL3_4
> > >> PAUSE DELAY
> > >> HIGH COIL1_2
> > >> LOW COIL3_4
> > >> PAUSE DELAY
> > >> LOW COIL1_2
> > >> LOW COIL3_4
> > >> PAUSE DELAY
> > >> LOW COIL1_2
> > >> HIGH COIL3_4
> > >> PAUSE DELAY
> > >> NEXT
> > >> END
Thanks for looking over my code and hook up, seems like I went thru every
permutation on the wiring from the UDN to the AirPax, but will check what
you suggested.
On the Airpax from Jameco, both the positive wires are red, I connected them
together to 12v. I ran a zener 2EZ15D5MSCT from the same 12v with the zigzag
end pointing to the UDN and ran it to pins 2 and 7.
Am planning on using the look up table once I get the Airpax up and running
decently.
The resistance between the brn & org is 115 ohms, between the brn & red its
59 ohms, between the brn & the other red(no green wire on this Airpax unit)
is 0.
Per Al Williams book I though I had it figured out.
Mark
Original Message
Date: Thursday, April 13, 2000 2:23 PM
>Mark:
>yellow to UDN pin 1
>orange to pin 3
>brown to pin 8
>black to pin 6
>manual, page 43.
>Good luck,
>Ray McArthur
Original Message
>> Mark:
incorrect
>yours
>were
>> decent quality.
>> Ray
Original Message
>> > Hi Ray:
>> know
>the
>> other
and
>> > UND2544B.
>> > pretty interesting.
>> > Mark
Original Message
>in
>> Airpax.
>torque
>coil
>high
>> a
>> high
>> that
>by
>> a
>> > >Ray McArthur
Original Message
>> > >> Hi all:
actuators
>> > give
>> > >> me a holler please.
>$9
>> > >buck
>on
>> > >this
>or
>> > >so?
>P/N
>> > >> 162587)
>> > >> 'ORG PIN 8
>> > >> 'BLK PIN 6
>> > >> 'BRN PIN 3
>> > >> 'YEL PIN 1
>WON'T
>> > >PRINT
>> > >> CTR VAR WORD
>> > >> DELAY VAR WORD
>> > >> STEPS VAR WORD
>> > >> COIL1_2 CON 0
>> > >> COIL3_4 CON 1
>> > >> DELAY = 2
>> > >> STEPS = 50
>> > >> 'Retract
>> > >> LOW COIL1_2
>> > >> HIGH COIL3_4
>> > >> PAUSE DELAY
>> > >> LOW COIL1_2
>> > >> LOW COIL3_4
>> > >> PAUSE DELAY
>> > >> HIGH COIL1_2
>> > >> LOW COIL3_4
>> > >> PAUSE DELAY
>> > >> HIGH COIL1_2
>> > >> HIGH COIL3_4
>> > >> PAUSE DELAY
>> > >> NEXT
>> > >> 'EXTEND
>> > >> HIGH COIL1_2
>> > >> HIGH COIL3_4
>> > >> PAUSE DELAY
>> > >> HIGH COIL1_2
>> > >> LOW COIL3_4
>> > >> PAUSE DELAY
>> > >> LOW COIL1_2
>> > >> LOW COIL3_4
>> > >> PAUSE DELAY
>> > >> LOW COIL1_2
>> > >> HIGH COIL3_4
>> > >> PAUSE DELAY
>> > >> NEXT
>> > >> END
Thanks for the detailed post, all very interesting and great stuff.
I guess what threw me off on the UDN2544 was that on the Allegro spec sheet
front page under Features it says "Inputs configured for Unipolar Stepper
Motors", so I guess you can drive a bipolar stepper with unipolar inputs?
Will check out the links you posted, especially on the EDE-1200 Uni-Polar
Stepper ASIC
I look forward to checking out their EDE-1200 App Note regarding (Airpax)
Linear Actuators big time.
Have you worked at all with digital encoders from US Digital, that will be
probably the next thing I'll be tackling once I get the Airpax up and
running.
Mark
Original Message
Cc: Todd Peterson <toddp@e...>
Date: Thursday, April 13, 2000 9:49 AM
Subject: Re: [noparse][[/noparse]basicstamps] [noparse][[/noparse]long] 2 pin BSC2 to stepper
>At 08:08 PM 4/12/00 -0700, techno_masai promulgated:
> here in the US]
>Mark and Ray:
>have -
>labelled
>center of
>you
>and
>have",
>ordered like
>determine that.
>little
>for some
site:
>Chip.
>Why ?
>manufacturers.
>(hint, hint),
>Actuators, relative
>other
and
>chips,
>like
>applications
>Hope that helps.
>Regards,
>Bruce
>>Hi Ray:
know
other
>>UND2544B.
>>pretty interesting.
>>Mark
Original Message
Airpax.
a
high
that
a
>>>Ray McArthur
Original Message
>>>> Hi all:
>>give
>>>> me a holler please.
>>>buck
>>>this
>>>so?
>>>> 162587)
>>>> 'ORG PIN 8
>>>> 'BLK PIN 6
>>>> 'BRN PIN 3
>>>> 'YEL PIN 1
>>>PRINT
>>>> CTR VAR WORD
>>>> DELAY VAR WORD
>>>> STEPS VAR WORD
>>>> COIL1_2 CON 0
>>>> COIL3_4 CON 1
>>>> DELAY = 2
>>>> STEPS = 50
>>>> 'Retract
>>>> LOW COIL1_2
>>>> HIGH COIL3_4
>>>> PAUSE DELAY
>>>> LOW COIL1_2
>>>> LOW COIL3_4
>>>> PAUSE DELAY
>>>> HIGH COIL1_2
>>>> LOW COIL3_4
>>>> PAUSE DELAY
>>>> HIGH COIL1_2
>>>> HIGH COIL3_4
>>>> PAUSE DELAY
>>>> NEXT
>>>> 'EXTEND
>>>> HIGH COIL1_2
>>>> HIGH COIL3_4
>>>> PAUSE DELAY
>>>> HIGH COIL1_2
>>>> LOW COIL3_4
>>>> PAUSE DELAY
>>>> LOW COIL1_2
>>>> LOW COIL3_4
>>>> PAUSE DELAY
>>>> LOW COIL1_2
>>>> HIGH COIL3_4
>>>> PAUSE DELAY
>>>> NEXT
>>>> END
Your wire colors are different than I thought. Could you give me a list of
all the wire colors and resistance readings between them? I am interested
in your project because I am considering buying one of those steppers.
Ray McArthur
Original Message
Sent: Friday, April 14, 2000 5:21 PM
> Hi Ray:
> you suggested.
them
zigzag
running
> decently.
its
unit)
> is 0.
> Mark
Original Message
> >Mark:
> >yellow to UDN pin 1
> >orange to pin 3
> >brown to pin 8
> >black to pin 6
can
> >manual, page 43.
> >Good luck,
> >Ray McArthur
Original Message
> >> Mark:
> incorrect
check
resistance.
> >yours
would
> >were
> >> decent quality.
> >> Ray
Original Message
> >> > Hi Ray:
don't
> >> know
read
> >the
> >> other
> and
the
> >> > UND2544B.
a
all
> >> > pretty interesting.
> >> > Mark
Original Message
delay=2
> >in
> >> Airpax.
> >torque
> >coil
> >high
> >> a
at
> >> high
bet
> >> that
somewhat
> >by
> >> a
> >> > >Ray McArthur
Original Message
> >> > >> Hi all:
> actuators
> >> > give
> >> > >> me a holler please.
low
> >$9
> >> > >buck
back
> >on
> >> > >this
LBF
> >or
> >> > >so?
(JAMECO
> >P/N
> >> > >> 162587)
> >> > >> 'ORG PIN 8
> >> > >> 'BLK PIN 6
> >> > >> 'BRN PIN 3
> >> > >> 'YEL PIN 1
> >WON'T
> >> > >PRINT
> >> > >> CTR VAR WORD
> >> > >> DELAY VAR WORD
> >> > >> STEPS VAR WORD
> >> > >> COIL1_2 CON 0
> >> > >> COIL3_4 CON 1
> >> > >> DELAY = 2
> >> > >> STEPS = 50
> >> > >> 'Retract
> >> > >> LOW COIL1_2
> >> > >> HIGH COIL3_4
> >> > >> PAUSE DELAY
> >> > >> LOW COIL1_2
> >> > >> LOW COIL3_4
> >> > >> PAUSE DELAY
> >> > >> HIGH COIL1_2
> >> > >> LOW COIL3_4
> >> > >> PAUSE DELAY
> >> > >> HIGH COIL1_2
> >> > >> HIGH COIL3_4
> >> > >> PAUSE DELAY
> >> > >> NEXT
> >> > >> 'EXTEND
> >> > >> HIGH COIL1_2
> >> > >> HIGH COIL3_4
> >> > >> PAUSE DELAY
> >> > >> HIGH COIL1_2
> >> > >> LOW COIL3_4
> >> > >> PAUSE DELAY
> >> > >> LOW COIL1_2
> >> > >> LOW COIL3_4
> >> > >> PAUSE DELAY
> >> > >> LOW COIL1_2
> >> > >> HIGH COIL3_4
> >> > >> PAUSE DELAY
> >> > >> NEXT
> >> > >> END
>Hi Bruce:
If the truth would be know bi-polar/uni-polar are almost connectivity
methods, but
it kinda fails the true test. The direct answer to your question is yes.
>Stepper ASIC
You will appreciate the docs (free) and the assistance, I can assure you.
I surely am in no position except to HINT at something like that <smile>.
>running.
Some, but not extensively. I had an application I was going to get involved in
about 6 months ago, but it never got off the ground. I have the docs
though, and various "typical" examples of various encoders. I never
filtered thru it to see if there was one which mentioned the US Digital
ones. Which encoder were you looking
to use, and what is the exact application ?
Bruce
>Mark
The UDN 2544 should drive a unipolar stepper if connected as their example
circuit that you are using. If one of your stamp pins drives UDN pins 9&10,
and the other stamp pin drives UDN pins 15&16, there should be no problem.
I have an EDE1200 driving a stepper, and it works fine, but so should your
UDN.
Will check out the Airpax site Bruce mentioned, but I think I already have
it downloaded.
Ray McArthur
Original Message
Sent: Friday, April 14, 2000 5:45 PM
> Hi Bruce:
sheet
> Stepper ASIC
> running.
> Mark
Original Message
> From: Bruce Bates <bvbates@u...>
> > here in the US]
> >Mark and Ray:
mail
> >have -
> >labelled
> >center of
like,
> >you
> >and
> >have",
> >ordered like
> >determine that.
> >little
catalog.
> >for some
> site:
> >Chip.
> >Why ?
> >manufacturers.
required,
> >(hint, hint),
> >Actuators, relative
(or
> >other
so
> and
> >chips,
used
> >like
> >applications
but
> >Hope that helps.
> >Regards,
> >Bruce
> >>Hi Ray:
> know
the
> other
> >>UND2544B.
> >>pretty interesting.
> >>Mark
Original Message
in
> Airpax.
torque
coil
high
> a
> high
> that
by
> a
> >>>Ray McArthur
Original Message
> >>>> Hi all:
> >>give
> >>>> me a holler please.
$9
> >>>buck
on
> >>>this
> >>>so?
P/N
> >>>> 162587)
> >>>> 'ORG PIN 8
> >>>> 'BLK PIN 6
> >>>> 'BRN PIN 3
> >>>> 'YEL PIN 1
WON'T
> >>>PRINT
> >>>> CTR VAR WORD
> >>>> DELAY VAR WORD
> >>>> STEPS VAR WORD
> >>>> COIL1_2 CON 0
> >>>> COIL3_4 CON 1
> >>>> DELAY = 2
> >>>> STEPS = 50
> >>>> 'Retract
> >>>> LOW COIL1_2
> >>>> HIGH COIL3_4
> >>>> PAUSE DELAY
> >>>> LOW COIL1_2
> >>>> LOW COIL3_4
> >>>> PAUSE DELAY
> >>>> HIGH COIL1_2
> >>>> LOW COIL3_4
> >>>> PAUSE DELAY
> >>>> HIGH COIL1_2
> >>>> HIGH COIL3_4
> >>>> PAUSE DELAY
> >>>> NEXT
> >>>> 'EXTEND
> >>>> HIGH COIL1_2
> >>>> HIGH COIL3_4
> >>>> PAUSE DELAY
> >>>> HIGH COIL1_2
> >>>> LOW COIL3_4
> >>>> PAUSE DELAY
> >>>> LOW COIL1_2
> >>>> LOW COIL3_4
> >>>> PAUSE DELAY
> >>>> LOW COIL1_2
> >>>> HIGH COIL3_4
> >>>> PAUSE DELAY
> >>>> NEXT
> >>>> END
Here's what I got:
red-red1 0
yel-org 0
yel-red 59
yel-red1 0
yel-blk 120
yel-brn 0
org-brn 116
org-red 0
org-red1 57
org-brn 116
org-blk 0
brn-red 0
brn-red1 59
brn-blk 0
blk-red1 0
blk-red 60
Hope I got them all. I arbitrarily called one of the two identical red wires
red1.
The label on this Airpax stepper linear actuator has these numbers A92218,
8232
Hope to hear about your luck with these linear actuators.
Mark
Original Message
Date: Friday, April 14, 2000 2:53 PM
>Mark:
>Thanks,
>Ray McArthur
Original Message
>> Hi Ray:
>> you suggested.
>them
>zigzag
>running
>> decently.
>its
>unit)
>> is 0.
>> Mark
Original Message
>> >Mark:
the
>> >yellow to UDN pin 1
>> >orange to pin 3
>> >brown to pin 8
>> >black to pin 6
>can
stamp
>> >manual, page 43.
>> >Good luck,
>> >Ray McArthur
Original Message
>> >> Mark:
at
>> incorrect
>check
>resistance.
>> >yours
>would
>> >were
>> >> decent quality.
>> >> Ray
Original Message
>> >> > Hi Ray:
>don't
>> >> know
>read
get
>> >the
at
>> >> other
>> and
>the
>> >> > UND2544B.
been
>a
>all
>> >> > pretty interesting.
>> >> > Mark
Original Message
>delay=2
>> >in
>> >> Airpax.
>> >torque
>> >coil
>> >high
>> >> a
>at
>> >> high
>bet
>> >> that
>somewhat
>> >by
>> >> a
>> >> > >Ray McArthur
Original Message
>> >> > >> Hi all:
>> actuators
>> >> > give
>> >> > >> me a holler please.
>low
>> >$9
>> >> > >buck
>back
>> >on
>> >> > >this
>LBF
>> >or
>> >> > >so?
>(JAMECO
>> >P/N
>> >> > >> 162587)
>> >> > >> 'ORG PIN 8
>> >> > >> 'BLK PIN 6
>> >> > >> 'BRN PIN 3
>> >> > >> 'YEL PIN 1
>> >WON'T
>> >> > >PRINT
>> >> > >> CTR VAR WORD
>> >> > >> DELAY VAR WORD
>> >> > >> STEPS VAR WORD
>> >> > >> COIL1_2 CON 0
>> >> > >> COIL3_4 CON 1
>> >> > >> DELAY = 2
>> >> > >> STEPS = 50
>> >> > >> 'Retract
>> >> > >> LOW COIL1_2
>> >> > >> HIGH COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> LOW COIL1_2
>> >> > >> LOW COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> HIGH COIL1_2
>> >> > >> LOW COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> HIGH COIL1_2
>> >> > >> HIGH COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> NEXT
>> >> > >> 'EXTEND
>> >> > >> HIGH COIL1_2
>> >> > >> HIGH COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> HIGH COIL1_2
>> >> > >> LOW COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> LOW COIL1_2
>> >> > >> LOW COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> LOW COIL1_2
>> >> > >> HIGH COIL3_4
>> >> > >> PAUSE DELAY
>> >> > >> NEXT
>> >> > >> END
Thanks for the info. From your readings, you should try:
* both reds to plus, like you have.
* brown to UDN pin 3.
* orange to pin 1.
* yellow to pin 8.
* black to pin 6.
Don' forget to try longer delays, like 40 if it's weird.
Let me know how you make out,
Ray McArthur
Original Message
Sent: Friday, April 14, 2000 10:50 PM
> Sure Ray:
> Here's what I got:
> red-red1 0
> yel-org 0
> yel-red 59
> yel-red1 0
> yel-blk 120
> yel-brn 0
> org-brn 116
> org-red 0
> org-red1 57
> org-brn 116
> org-blk 0
> brn-red 0
> brn-red1 59
> brn-blk 0
> blk-red1 0
> blk-red 60
wires
> red1.
> 8232
> Mark
Original Message
> >Mark:
of
interested
> >Thanks,
> >Ray McArthur
Original Message
> >> Hi Ray:
every
what
> >> you suggested.
> >them
> >zigzag
> >running
> >> decently.
> >its
> >unit)
> >> is 0.
> >> Mark
Original Message
> >> >Mark:
your
V1.9
> the
> >> >yellow to UDN pin 1
> >> >orange to pin 3
> >> >brown to pin 8
> >> >black to pin 6
You
> >can
> stamp
> >> >manual, page 43.
> >> >Good luck,
> >> >Ray McArthur
Original Message
> >> >> Mark:
> at
> >> incorrect
> >check
> >resistance.
but
> >> >yours
> >would
seen
> >> >were
> >> >> decent quality.
> >> >> Ray
Original Message
> >> >> > Hi Ray:
> >don't
> >> >> know
> >read
> get
> >> >the
> at
> >> >> other
steps
> >> and
the
more
for
> >the
> >> >> > UND2544B.
> been
> >a
> >all
> >> >> > pretty interesting.
> >> >> > Mark
Original Message
> >delay=2
> >> >in
from
> >> >> Airpax.
> >> >torque
that
> >> >coil
too
> >> >high
> >> >> a
torque
> >at
> >> >> high
will
> >bet
> >> >> that
> >somewhat
> >> >by
> >> >> a
> >> >> > >Ray McArthur
Original Message
> >> >> > >> Hi all:
> >> actuators
> >> >> > give
> >> >> > >> me a holler please.
> >low
> >> >$9
> >> >> > >buck
> >back
> >> >on
> >> >> > >this
1
> >LBF
> >> >or
> >> >> > >so?
> >(JAMECO
> >> >P/N
> >> >> > >> 162587)
> >> >> > >> 'ORG PIN 8
> >> >> > >> 'BLK PIN 6
> >> >> > >> 'BRN PIN 3
> >> >> > >> 'YEL PIN 1
IT
> >> >WON'T
> >> >> > >PRINT
> >> >> > >> CTR VAR WORD
> >> >> > >> DELAY VAR WORD
> >> >> > >> STEPS VAR WORD
> >> >> > >> COIL1_2 CON 0
> >> >> > >> COIL3_4 CON 1
> >> >> > >> DELAY = 2
> >> >> > >> STEPS = 50
> >> >> > >> 'Retract
> >> >> > >> LOW COIL1_2
> >> >> > >> HIGH COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> LOW COIL1_2
> >> >> > >> LOW COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> HIGH COIL1_2
> >> >> > >> LOW COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> HIGH COIL1_2
> >> >> > >> HIGH COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> NEXT
> >> >> > >> 'EXTEND
> >> >> > >> HIGH COIL1_2
> >> >> > >> HIGH COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> HIGH COIL1_2
> >> >> > >> LOW COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> LOW COIL1_2
> >> >> > >> LOW COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> LOW COIL1_2
> >> >> > >> HIGH COIL3_4
> >> >> > >> PAUSE DELAY
> >> >> > >> NEXT
> >> >> > >> END
>Mark:
>UDN.
>it downloaded.
Just as a matter of clarification, my comments were relative to the Jameco
Airpax actuator unit, and ONLY if it's the same unit as pictured on the
Thomson Mechatronics website.
Bruce
>Thanks,
>Ray McArthur
Original Message
>> Hi Bruce:
>sheet
>> Stepper ASIC
>> running.
>> Mark
Original Message
>> > here in the US]
>> >Mark and Ray:
>mail
>> >have -
>> >labelled
>> >center of
>like,
>> >you
>> >and
>> >have",
>> >ordered like
>> >determine that.
>> >little
>catalog.
>> >for some
>> site:
>> >Chip.
>> >Why ?
>> >manufacturers.
>required,
>> >(hint, hint),
>> >Actuators, relative
>(or
>> >other
>so
>> and
>> >chips,
>used
>> >like
>> >applications
>but
>> >Hope that helps.
>> >Regards,
>> >Bruce
>> >>Hi Ray:
>> know
>the
>> other
>> >>UND2544B.
>> >>pretty interesting.
>> >>Mark
Original Message
>in
>> Airpax.
>torque
>coil
>high
>> a
>> high
>> that
>by
>> a
>> >>>Ray McArthur
Original Message
>> >>>> Hi all:
>> >>give
>> >>>> me a holler please.
>$9
>> >>>buck
>on
>> >>>this
>or
>> >>>so?
>P/N
>> >>>> 162587)
>> >>>> 'ORG PIN 8
>> >>>> 'BLK PIN 6
>> >>>> 'BRN PIN 3
>> >>>> 'YEL PIN 1
>WON'T
>> >>>PRINT
>> >>>> CTR VAR WORD
>> >>>> DELAY VAR WORD
>> >>>> STEPS VAR WORD
>> >>>> COIL1_2 CON 0
>> >>>> COIL3_4 CON 1
>> >>>> DELAY = 2
>> >>>> STEPS = 50
>> >>>> 'Retract
>> >>>> LOW COIL1_2
>> >>>> HIGH COIL3_4
>> >>>> PAUSE DELAY
>> >>>> LOW COIL1_2
>> >>>> LOW COIL3_4
>> >>>> PAUSE DELAY
>> >>>> HIGH COIL1_2
>> >>>> LOW COIL3_4
>> >>>> PAUSE DELAY
>> >>>> HIGH COIL1_2
>> >>>> HIGH COIL3_4
>> >>>> PAUSE DELAY
>> >>>> NEXT
>> >>>> 'EXTEND
>> >>>> HIGH COIL1_2
>> >>>> HIGH COIL3_4
>> >>>> PAUSE DELAY
>> >>>> HIGH COIL1_2
>> >>>> LOW COIL3_4
>> >>>> PAUSE DELAY
>> >>>> LOW COIL1_2
>> >>>> LOW COIL3_4
>> >>>> PAUSE DELAY
>> >>>> LOW COIL1_2
>> >>>> HIGH COIL3_4
>> >>>> PAUSE DELAY
>> >>>> NEXT
>> >>>> END
Wow, that was it, thing runs like a charm now, thank you very much!
Darn and I must have gone thru that combo at least once, I'm not sure how I
missed it.
Funny thing is that it runs really fast and snappy at delay = 2 too, and
like you said runs great at 40.
Dogone this thing is neat now!
Saw your post on the VFD, haven't worked on serial connections to these
either, but there must be a Register Select command to get your characters
into the 2nd 8 characters on the display, as you more than likely know its
like %11000000 on the parallel driven Optrex.
Guess I'm trying to offer up some probably rather pathetic help here since
I'm pretty indebted to your assistance Ray.
Thanks again,
Mark
Original Message
Date: Friday, April 14, 2000 8:33 PM
>Mark:
>* orange to pin 1.
>* yellow to pin 8.
>* black to pin 6.
>Ray McArthur
Original Message
>> Sure Ray:
>> Here's what I got:
>> red-red1 0
>> yel-org 0
>> yel-red 59
>> yel-red1 0
>> yel-blk 120
>> yel-brn 0
>> org-brn 116
>> org-red 0
>> org-red1 57
>> org-brn 116
>> org-blk 0
>> brn-red 0
>> brn-red1 59
>> brn-blk 0
>> blk-red1 0
>> blk-red 60
>wires
>> red1.
A92218,
>> 8232
>> Mark
Original Message
>> >Mark:
>of
>interested
>> >Thanks,
>> >Ray McArthur
Original Message
>> >> Hi Ray:
>every
>what
>> >> you suggested.
connected
>> >them
>> >zigzag
>> >running
>> >> decently.
red
>> >its
>> >unit)
>> >> is 0.
>> >> Mark
Original Message
>> >> >Mark:
>your
>V1.9
>> the
>> >> >yellow to UDN pin 1
>> >> >orange to pin 3
>> >> >brown to pin 8
>> >> >black to pin 6
>You
>> >can
>> stamp
>> >> >manual, page 43.
>> >> >Good luck,
>> >> >Ray McArthur
Original Message
>> >> >> Mark:
occur
>> at
>> >> incorrect
>> >check
>> >resistance.
>but
>> >> >yours
>> >would
>seen
>> >> >were
>> >> >> decent quality.
>> >> >> Ray
Original Message
>> >> >> > Hi Ray:
>> >don't
>> >> >> know
to
>> >read
>> get
>> >> >the
steps,
>> at
>> >> >> other
>steps
>> >> and
>the
>more
>for
>> >the
>> >> >> > UND2544B.
>> been
>> >a
they're
>> >all
>> >> >> > pretty interesting.
>> >> >> > Mark
Original Message
>> >delay=2
>> >> >in
>from
>> >> >> Airpax.
cases,
>> >> >torque
>that
>> >> >coil
>too
>> >> >high
>> >> >> a
>torque
>> >at
>> >> >> high
>will
>> >bet
>> >> >> that
>> >somewhat
>> >> >by
>> >> >> a
>> >> >> > >Ray McArthur
Original Message
>> >> >> > >> Hi all:
>> >> actuators
>> >> >> > give
>> >> >> > >> me a holler please.
the
>> >low
>> >> >$9
>> >> >> > >buck
feed
>> >back
>> >> >on
>> >> >> > >this
>1
>> >LBF
>> >> >or
>> >> >> > >so?
>> >(JAMECO
>> >> >P/N
>> >> >> > >> 162587)
>> >> >> > >> 'ORG PIN 8
>> >> >> > >> 'BLK PIN 6
>> >> >> > >> 'BRN PIN 3
>> >> >> > >> 'YEL PIN 1
>IT
>> >> >WON'T
>> >> >> > >PRINT
>> >> >> > >> CTR VAR WORD
>> >> >> > >> DELAY VAR WORD
>> >> >> > >> STEPS VAR WORD
>> >> >> > >> COIL1_2 CON 0
>> >> >> > >> COIL3_4 CON 1
>> >> >> > >> DELAY = 2
>> >> >> > >> STEPS = 50
>> >> >> > >> 'Retract
>> >> >> > >> LOW COIL1_2
>> >> >> > >> HIGH COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> LOW COIL1_2
>> >> >> > >> LOW COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> HIGH COIL1_2
>> >> >> > >> LOW COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> HIGH COIL1_2
>> >> >> > >> HIGH COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> NEXT
>> >> >> > >> 'EXTEND
>> >> >> > >> HIGH COIL1_2
>> >> >> > >> HIGH COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> HIGH COIL1_2
>> >> >> > >> LOW COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> LOW COIL1_2
>> >> >> > >> LOW COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> LOW COIL1_2
>> >> >> > >> HIGH COIL3_4
>> >> >> > >> PAUSE DELAY
>> >> >> > >> NEXT
>> >> >> > >> END
Glad to hear it's working. How much thrust force does it have? Probably
more thrust at low speeds. My display is working now using commands
outlined in Scott Edwards docs, but I still have questions to post.
Ray McArthur
Original Message
Sent: Saturday, April 15, 2000 1:59 AM
> Ray:
I
> missed it.
> Thanks again,
> Mark
Original Message
> >Mark:
> >* orange to pin 1.
> >* yellow to pin 8.
> >* black to pin 6.
> >Ray McArthur
Original Message
> >> Sure Ray:
> >> Here's what I got:
> >> red-red1 0
> >> yel-org 0
> >> yel-red 59
> >> yel-red1 0
> >> yel-blk 120
> >> yel-brn 0
> >> org-brn 116
> >> org-red 0
> >> org-red1 57
> >> org-brn 116
> >> org-blk 0
> >> brn-red 0
> >> brn-red1 59
> >> brn-blk 0
> >> blk-red1 0
> >> blk-red 60
> >wires
> >> red1.
> A92218,
> >> 8232
Probably getting a least a couple lbs force, maybe up to around 5, anyway a
lot more force than I thought could be gotten out of this thing.
On hold torque, I'm guessing the weak link would be the UND2544 or would the
coils tend to overheat.
Guess the UND would be OK since its rated for 1.8A continuous, the Airpax is
running 12v/60ohms=200mA so seems like a good enough margin there.
Took apart an old pen plotter I had, the bipolar steppers were very small
but the power IC's and heat sinks were just huge, so I guess they figure a
lot of heat build up, and the only loading is moving the pen around.
Mark
Original Message
Date: Saturday, April 15, 2000 2:28 PM
>Mark:
>Regards,
>Ray McArthur
Original Message
>> Ray:
>I
>> missed it.
characters
its
since
>> Thanks again,
>> Mark
Original Message
>> >Mark:
>> >* orange to pin 1.
>> >* yellow to pin 8.
>> >* black to pin 6.
>> >Ray McArthur
Original Message
>> >> Sure Ray:
>> >> Here's what I got:
>> >> red-red1 0
>> >> yel-org 0
>> >> yel-red 59
>> >> yel-red1 0
>> >> yel-blk 120
>> >> yel-brn 0
>> >> org-brn 116
>> >> org-red 0
>> >> org-red1 57
>> >> org-brn 116
>> >> org-blk 0
>> >> brn-red 0
>> >> brn-red1 59
>> >> brn-blk 0
>> >> blk-red1 0
>> >> blk-red 60
>> >wires
>> >> red1.
>> A92218,
>> >> 8232
Ray
Original Message
Sent: Saturday, April 15, 2000 11:38 PM
> Hi Ray:
a
the
is
> Mark
Original Message
> >Mark:
> >Regards,
> >Ray McArthur
Original Message
> >> Ray:
how
> >I
> >> missed it.
and
> characters
> its
> since
> >> Thanks again,
> >> Mark
Original Message
> >> >Mark:
> >> >* orange to pin 1.
> >> >* yellow to pin 8.
> >> >* black to pin 6.
> >> >Ray McArthur
Original Message
> >> >> Sure Ray:
> >> >> Here's what I got:
> >> >> red-red1 0
> >> >> yel-org 0
> >> >> yel-red 59
> >> >> yel-red1 0
> >> >> yel-blk 120
> >> >> yel-brn 0
> >> >> org-brn 116
> >> >> org-red 0
> >> >> org-red1 57
> >> >> org-brn 116
> >> >> org-blk 0
> >> >> brn-red 0
> >> >> brn-red1 59
> >> >> brn-blk 0
> >> >> blk-red1 0
> >> >> blk-red 60
red
> >> >wires
> >> >> red1.
> >> A92218,
> >> >> 8232
