Circuit for 0-1 amp variable current
Hi
I have a proportional valve that requires variable current to operate. At
approximately 800 mA the valve is fully open. It is proportional from approx
0 amps to 800 mA. I want to drive the valve with a pic or stamp.
Can anyone recommend a circuit that a pic or stamp can drive which can output
that range of variable current?
Maybe PWM at a high frequency?
Any help would be great.
Jon
Jon
>Hi
output
>Thanks
>Jon
Hi Jon -
There was an <ahem> seminar on the old stamp list on this very topic <g>.
I can probably strip it off my own Stamp List archives, and zip it
for you ???
I have NO idea what to tell you otherwise, since the off-site Stamp archive
is quite out-of-date, and I'm not exactly sure of the status of the Parallax
site, as regards archives.
Honestly - I haven't even looked at the new Parallax website, I'm sorry to
say;
too darned busy. Don't need to for archives when ya keep yer own, though <g>.
For you, the fee will be reasonable <grin>.
Lemme know whatch wanna do, kind sir.
Bruce
>eGroups.com home: http://www.egroups.com/group/basicstamps
>http://www.egroups.com - Simplifying group communications
You might want to check the National Semiconductor data books or web site.
In App Note 31, there are many op-amp circuits including a current source
and sink. Also, take a look at the LM675 power op-amp. The data sheet for
this guy shows a high current source/sink. You could use the PWM output of
the Stamp w/filter to drive the op-amp of the current source/sink.
At 01:09 AM 30/3/00 -0500, you wrote:
>Hi
>Thanks
>Jon
258 Metals Development
Ames Laboratory
Iowa State University
approx
output
Hi Jon,
Here is a classic voltage controlled current sink, 100% PWM at P0 gives
800ma to the valve.
Current proportional to %PWM.
o
+24 volts
op-amp | |
LM358 | valve 0->800ma
P0--/\/\-o--- |+\ |/----'
10k | | >--| NPN adequate power
| ;--|-/ |\>-; or mosfet
o
1uf=== /
| \ 6.25 ohms, 5 watt
o
o----Vss
The stamp can come around once every few seconds to refresh the charge on
the PWM capacitor.
--Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
Jon
In a message dated 3/30/00 12:41:10 PM US Mountain Standard Time,
harker@a... writes:
<< Jon,
the Stamp w/filter to drive the op-amp of the current source/sink >>
That sounds like a neat valve! Could you tell me the make, model and price
range?
Roger
>approx
>output
>Hi Jon,
>800ma to the valve.
o
+24 volts
> op-amp | |
o
> 1uf=== /
> | \ 6.25 ohms, 5 watt
o
o----Vss
>the PWM capacitor.
> --Tracy Allen
Roger Edberg
rjedberg@c...
http://www.cruzio.com/~pgraphic
I am also interested in this valve. Can you tell me the orfice size along
with everything below.
Derek Barger
>Hi Jon,
>range?
>Thanks,
>Roger
>>approx
>>output
>>Hi Jon,
>>800ma to the valve.
o
+24 volts
>> op-amp | |
o
>> 1uf=== /
>> | \ 6.25 ohms, 5 watt
o
o----Vss
>>the PWM capacitor.
>> --Tracy Allen
>Roger Edberg
>rjedberg@c...
