off topic, obd II to serial
Does anyone know of an inexpensive source
for an ODB II - to - serial chip/kit/method??
I'm trying to build a reader for the
chrysler jeep cheroke vehicle.
Rick
also, off topic, I never seem to get through
to the list by just emailing to 'basicstamps@egroups.com';
I'm always forced to use their web page. What am I doing
wrong when using 'direct' email??
thanks
Rick
thanks
From what I've seen to date, it would be very difficult, if not impossible to
do with a Stamp. With a PIC it might be doable - so you might check the PIC
lists.
I have NO IDEA what state the PIC lists are in at present.
>Thanks
>Rick
>thanks
>-- Easily schedule meetings and events using the group calendar!
>-- http://www.egroups.com/cal?listname=basicstamps&m=1
He has a preprogrammed PIC that will allow you to get OBDII data.
I havent been able to get the stuff to work on certain cars through.
Original Message
To: <basicstamps@egroups.com>
Sent: Sunday, March 26, 2000 11:41 PM
Subject: [noparse][[/noparse]basicstamps] Re: off topic, obd II to serial
> At 12:33 PM 3/26/00 -0800, R. Denzer promulgated:
to
PIC
> lists.
> >Thanks
> >Rick
> >thanks
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
Original Message
Sent: Monday, March 27, 2000 7:04 AM
> Check http://www.obd2.com/
Original Message
> From: Bruce Bates <bvbates@u...>
impossible
> to
> PIC
> > lists.
> > >Thanks
> > >Rick
> > >thanks
> -- Check out your group's private Chat room
> -- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
there he has a ISO chip for OEM applications.
http://www.obd-2.com/chip.htm
Original Message
Sent: Monday, March 27, 2000 9:51 PM
> a) Are you referring to the various $30 - $50 cables with serial
> terminator? Is this enough for raw data gathering?
> b) On a BasicStamp (or Windows terminal emulator) can you view the raw
data
> from the cable?
> Thanks,
> Larry Pfeffer
Original Message
impossible
> >to
> >PIC
> >> lists.
> >> >Thanks
> >> >Rick
> >> >thanks
> eGroups.com Home: http://www.egroups.com/group/basicstamps/
b) On a BasicStamp (or Windows terminal emulator) can you view the raw data
from the cable?
Larry Pfeffer
Original Message
>to
>PIC
>> lists.
>> >Thanks
>> >Rick
>> >thanks
