Palm to Stamp
We are in the planning stages of a project. We would like
to write the code and store on a Palm to later send to
the stamp through the infared port. Has anyone tied these
steps together before? Any thoughts or suggestions are
welcome.
David
welcome.
David
I myself posted a similar question just last week! Here is the response I
received.
>Take a look at www.orbworks.com and their Pocket C. I've used it with both
>the Palm OS and with Windows CE (my prefered hand-held platform). If
you've
>never programmed in C there will be a bit of a learning curve, but it's not
>too steep.
>-- Jon Williams
>-- Dallas, TX
I have started using it and it seems to be able to do anything I need it to
do.
Good Luck,
Roger Byrum
Logansport, IN
Original Message
From: david@r... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3hTMBkjondJvA7wNzp_qmoMapgEn2xEPE3eiK9G0QHHEKp8at1mORAwNg4qLmyKqHHsljeuIRM7J7w]david@r...[/url
Sent: Tuesday, March 21, 2000 12:00 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Palm to Stamp
welcome.
David
eGroups.com home: http://www.egroups.com/group/basicstamps
http://www.egroups.com - Simplifying group communications
This is a Java-lite for CE or Palm. You use the JDK to develop on a normal
Java platform and then download to the handheld.
I did a column on Waba in my Web Techniques column (www.webtechniques.com --
search for Waba).
Al Williams
AWC
* Add I/O to your Stamp project with a PAK-III or PAK-IV:
www.al-williams.com/awce/pak3.htm
Original Message
> From: Roger E. Byrum [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CO7wu8AofDJPGLaT3slzFn1HCrHAFMbGCy3_5UEcUWAMT4ub0s6ohHARWFrgMGhs8kfHlOf_zU1pDHdpSHHu]roger@m...[/url
> Sent: Wednesday, March 22, 2000 7:47 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Palm to Stamp
> Dear David,
> received.
> it with both
> you've
> but it's not
> >too steep.
> >-- Jon Williams
> >-- Dallas, TX
> need it to
> do.
> Good Luck,
> Roger Byrum
> Logansport, IN
Original Message
> From: david@r... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DAa_3Eu6jqtKFrC_3R8g8QkJUNKacmW7piN5771EXjiEofh8ZdlXlUZn8_7cy-vG8DAhScrOkZf8]david@r...[/url
> welcome.
> Thanks,
> David
http://www.nsbasic.com/
for IrDA?
Larry Pfeffer
Jerusalem, Israel
At 08:47 AM 3/22/00 -0500, you wrote:
>Dear David,
>received.
>you've
>>too steep.
>>-- Jon Williams
>>-- Dallas, TX
>do.
>Good Luck,
>Roger Byrum
>Logansport, IN
Original Message
>From: david@r... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qXyIcI_VTUHOKLwknYs24OZ_QHxHIZCb0feXQBrQVHpt-8X7TofsXCXcMo8Brd34ajcxi4hhgrxr76uP]david@r...[/url
>welcome.
>Thanks,
>David
to a file instead of the com port? I want to be able to store the file on
a Palm and then send it to the stamp.
David
david@r... writes:
> Is it possible to redirect the tokenized data from the Stamp Editor
The DOS version of the BS1 compiler has a command called BSAVE that writes
the EEPROM image to a file called CODE.OBJ.
-- Jon Williams
-- Dallas, TX
