Shaft encoders for wheeled robot?
Has anyone implemented shaft encoders for their wheeled robot?? I am trying
to locate a source for shaft encoders as well as encoder wheels, some of my
projects use modified servo motors for wheels, while others use dc motors.
What I would like to do is something like the Descartes robot. Any help
appreciated.
appreciated.
digi-key, don't know the part number off hand I could find out if you like.
With a few modifications I managed to fit the in a futaba s-148 servo. My
next next step will be to write some code for a pair of 12c671s to decode
them
>From: "CPWRobotics" <charley@c...>
>Reply-To: basicstamps@egroups.com
>To: "Stamp Mailing List" <basicstamps@egroups.com>
>Subject: [noparse][[/noparse]basicstamps] Shaft encoders for wheeled robot?
>Date: Mon, 20 Mar 2000 15:39:11 -0500
>appreciated.
>-- 20 megs of disk space in your group's Document Vault
>-- http://www.egroups.com/docvault/basicstamps/?m=1
______________________________________________________
called Hamamatsu, its used on the rug warrior robot, of course I still
haven't found a source for the encoder wheels. I know there are different
ways to do this, however I would like the most reliable way, and hopefully
not spend a fortune doing it. Thanks again.
Original Message
To: <basicstamps@egroups.com>
Sent: Monday, March 20, 2000 7:51 PM
Subject: [noparse][[/noparse]basicstamps] Re: Shaft encoders for wheeled robot?
> I'm working on this idea know. I got a couple cheat shaft encoders from
like.
> them
trying
my
motors.
> >appreciated.
> -- Easily schedule meetings and events using the group calendar!
> -- http://www.egroups.com/cal?listname=basicstamps&m=1
and print it out on white card. A photo-diode/LED combo set for close
range reflective function could pick off the code. If you need absolute position
then you could print a code wheel with the required resolution , 8 bits will
give you
slighly more than 1 degree. You'll need as many photo-diode/LED combos
as the number of bits. 8 bits would work well withe the SHIFTIN via a 74HC165 8
bits in and serial out,
this only takes up 2 pins.
Another way is to use a angular sensing Hall device and a small magnet that
rotates, you then
use an A/D to put the data into the STAMP
I don't know what you are going to use the encoded output for so
otherwise I might have some other ideas.
Date sent: Mon, 20 Mar 2000 22:59:15 -0500
Send reply to: basicstamps@egroups.com
> I would definitely appreciate it. I also found a very small photoreflectors,
Original Message
> From: "ED Ward" <punk__rocker@h...>
> like.
> > them
> trying
> my
> motors.
> > >appreciated.
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
robot.
Original Message
Sent: Monday, March 20, 2000 11:21 PM
> If you need a simple encoder wheel you can draw one on the PC
position
will give you
74HC165 8 bits in and serial out,
that rotates, you then
photoreflectors,
different
hopefully
Original Message
from
> > like.
My
decode
> > > them
> > trying
of
> > my
> > motors.
help
> > > >appreciated.
> Ronald Doctors
> -- Check out your group's private Chat room
> -- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
-William
Original Message
Sent: Monday, March 20, 2000 10:59 PM
photoreflectors,
Original Message
> like.
My
decode
> > them
> trying
of
> my
> motors.
> > >appreciated.
those photoreflectors. I haven't been able to find a source for them yet.
Original Message
Sent: Tuesday, March 21, 2000 9:40 AM
> Where did you find the Hamamatsu photoreflectors??
> -William
Original Message
> From: CPWRobotics <charley@c...>
> photoreflectors,
different
hopefully
Original Message
from
> > like.
> My
> decode
> > > them
> > trying
> of
> > my
> > motors.
help
> > > >appreciated.
Joker Robotics, a dealer of the Rug Warrior in Germany
http://www.joker-robotics.com/
used to sell them separately. However, I did not find it in their new
catalog. It may be worth to ask them anyway.
Those Rug Warrior decoders do not seem to be very reliable. I presume that
light from other sources may interfere.
Werner
Am/Um 11:57 21.03.2000 -0500 schrieben Sie:
>Actually I had purchased a Rug Warrior Pro robot a while back, and it uses
Original Message
>From: "William Cox" <william@c...>
>> -William
3315C-1-006-ND
They're on page 448 in the most recent Canadian edition. Not sure if it
will be the same in the American version. Check it out, they cost me $3.91
Canadian.
>From: Werner Lehnberg <wl@G...>
>Date: Wed, 22 Mar 2000 08:53:37 +0100
>Hallo,
>Werner
>uses
Original Message
> >> -William
Original Message
Sent: Wednesday, March 22, 2000 8:29 PM
> forgive my lazyness. Here is the digikey part number of my shaft
encoders:
> 3315C-1-006-ND
$3.91
> Canadian.
> >Hallo,
that
> >Werner
> >uses
yet.
Original Message
> > >> -William
