Battery Status
Stampers
I am looking for an easy way for the Stamps 2 to check the battery status of
a 12 volt battery. Any ideas?
Thank you
Thank you
I just did an app. that had to monitor a 12 to 36v power supply with a
MAX187 12bit serial ADC. This thing worked great, and there's code
available for a BSII. Get the chip and the datasheet at:
http://www.maxim-ic.com
Get the code at:
http://www.hth.com/filelibrary/BS2-IC/
There's two versions of the code here, each slightly different. To measure
12V, you'll have to use a voltage divider to the ADC. If you don't know
what that is, there's a nifty online (java) calculator at:
http://www.woodsbas.demon.co.uk/calcs/vdivide.htm
Best, Duncan
above or bellow a determined limit.
(10 v for example.) A pin have a treshhold about 1.4 volt. Other available
pins may be used to check other
limits.
ACJacques.
Trkeenan@a... wrote:
> Stampers
> Thank you
> -- Easily schedule meetings and events using the group calendar!
> -- http://www.egroups.com/cal?listname=basicstamps&m=1
> battery status of a 12 volt battery. Any ideas?
RCtime can do this.
http://www.emesystems.com/BS2misc.htm#RCtime
470 ohm 100 kohm
P0 ----/\/\/\---o
/\/\/\----Vx unknown voltage
===== 0.1 uF film
Vss
And the BS2 test program is:
tx var word ' RCtime value
vx var word ' voltage value to be determined
Cn1 con 65000 ' first constant
Cn2 con 14 ' second constant
low 0
loop:
RCtime 0,0,tx
low 0
vx=Cn1 / tx - Cn2 / 2
debug home,dec? tx,"vx=",dec vx/10,".",dec1 vx
pause 1000
next
To calibrate, put a known voltage (say 12.6 volts) input at Vx an see what
answer you get out. Adjust the proportionality constant Cn1 to make it
come out right. Then put in a lower voltage (say 6.4 volts), and this time
adjust Cn2. Repeat for desired accuracy. It is accurate over a narrow
range of voltages typical of batteries in normal use.
-- Tracy Allen
Electronically Monitored Ecosystems
of
I needed such a critter and found a MAX666 from Maxim. I needed a device to
monitor a 12V gel cell and turn on a LED when it's voltage dropped to 10.5
volts. The 666 can do this. The indicating voltage is user settable. I have
the Maxim data sheet in .PDF format if you cannot find it on Maxim's web
site:
www.maxim-ic.com
Contact me OFF-LIST if you need the data sheet. Don't clog up the list with
requests.
Hope this helps.
Vic
_________________________________________
Victor Fraenckel vfraenc1@n...
Home of the WindReader Electronic Theodolite
Read the WIND
e-mail me back.
Derek
>of
tim
emesys@c... writes:
<< > I am looking for an easy way for the Stamps 2 to check the
RCtime can do this.
Nice web page. Thanks for your help. The battery monitor idea worked real
well.
Tim
