need mangetic sensor
I want to mount a magnet on a wheel and have the stamp sense the magnet
passing by
I want to signal conditioning to be built in so that the stamp just needs to
look for hi or lo
whats is this called, who sells it, for how mauch
thanks
richard
passing by
look for hi or lo
thanks
richard
and may need some signal conditioning depending on the exact device you
select. If the wheel turns slowly, you might be able to get away with a reed
switch. This is like a relay operated by an external magnet. These are
commonly used in alarm systems to detect when a door/window is open. Of
course, they need some time to recover and like all physical switches may
have bounce. So you'd want to debounce it in software and you couldn't
measure anything too fast that way.
Good luck,
Al Williams
AWC
*Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce
Original Message
> From: dakota [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=09anlI69LzUzh22RCUiKz_4xeHUPGigSdqemvzSmVogqjBwg5ZUHPy0XnAYbMUDL]umc@i...[/url
> Sent: Monday, March 13, 2000 9:33 AM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] need mangetic sensor
> passing by
> just needs to
> look for hi or lo
> thanks
> richard
> -- 20 megs of disk space in your group's Document Vault
> -- http://www.egroups.com/docvault/basicstamps/?m=1
9208B, 18-page book summarizing different Hall ICs and their
characteristics, part # HE510-ND, pack of 10 small magnets, and part #
DN6851A-ND, bi-pullup SIP Hall effect sensor.
Dennis
Original Message
From: dakota [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=frqxe9RrTzox95UnwCZFscieDCawh9QYVBfLsVEoB3Hi8p-gTvz6GMMlLOXuZwa2hwg]umc@i...[/url
Sent: Monday, March 13, 2000 7:33 AM
passing by
look for hi or lo
thanks
richard
the Stamp look for a simple switch closure? That would be a high,
wouldn't it?
Bob Oldham
> passing by
> look for hi or lo
> thanks
> richard
> passing by
> look for hi or lo
> thanks
> richard
