Problem with SX-Key on *one* computer
I recently purchased the SX-Tech Toolkit and serial transfers are *very* unstable on my primary workstation, an A-Bit NF7S running Windows XP. The serial port in question works fine with my modem, and the SX-Key seems to work fine on other computers. When I go to program the chip, the transfer will lock up midway through, or sometimes the software will fail to recognize the SX-Key entirely. I was able to program the chip once on this machine, but only after about a dozen attempts.
Fortunately I have a spare computer on a KVM at the moment that I can use to ptogram the SX-Key, but I'd really like to find a solution for my primary workstation. Has anyone else had any similar problems? Any potential solutions or work-arrounds?
-p.
-p.
1 - On the other machine(s) that work ok, what operating system (Win98, XP, etc) are you using?
2 - XP seems to be problematic for the SXKey. One common solution is to lower the FIFO buffers from the typical 14/16 to something like 4/4. Try lowering them substantially and see if that improves your situation.
I have attached a screenshot showing my settings. Don't take this as gospel, but merely as a starting point. You can also try unchecking the "Use FIFO buffers", and remove them from the equation completely.
Thanks, PeterM
I tried reducing the number of FIFO buffers, as well as disabling them entirely, but this did not help in any way. [noparse]:([/noparse]
Any other hints? Is there any official word on this from Parallax?
-p.
- rich
-p.
-p.
Jon Williams
Dallas Office
Jon Williams
Dallas Office
-p.
Jon Williams
Dallas Office
Jon Williams
Dallas Office
