GUI Bot software help
Has anyone used this software? I am using it in beginner mode and have turned off the sensors. My problem is the servos only turn for 1.2 secounds and no more even if I turn the time to the max which is 25.5 secounds.
Any help would be nice.
Randy
Randy
Dave
That did not help. One note I do not have the sensors installed. But... I thought that if I unchecked the box "sensors enabled" they would not be needed. I am trying to us this with a 3rd grade class and I wanted as little to get in the way as possible.
I want to use the bot on a table sitting on a big paper map of a city with roads and buildings drawn on it. The students would then try and direct using the GUI-Bot software. The car would start at one point on the map and drive it to another part of town.
Randy
Try the "Advanced" mode and see if it makes a difference.
Dave
Randy
Randy
I downloaded it for Parallax last year. The version is 1.0. Hope it works for you.
Let me know if you can not find it I can send you a copy.
Randy
I will have a look at the GUI-BOT software on my old Parallax CDs this weekend. The Parallax CD that came with this years' BOE-BOT has version 1.2.
