Need a Tachometer
Hi all, just registered on this site.
I'm looking for design ideas to make a reasonably·accurate automotive tachometer for a point based V8.· and reading into a legacy BS2-IC.· If it's (likely) already been done, would anyone share their efforts?· I am hoping to build an engine monitoring interface and data logging into a Pocket PC.· I prefer not to use hall effect but rather use the existing pulse based signal going to the analogue tach.
Many thanks in advance.
Gary
Perhaps there is already a cost effective prefab tach chip/module that outputs serial RPM data without too much supporting components?
Fred
a. set up a magnet or similar pick up circuit on the ditributor's rotor.
b. run into a pulse conditioning circuit.
c. run the output of the pulse conditioning circuit into the stamp through one input using the COUNT command. You would have to do some experimenting for the sample time but it would probably be between 100 ms and 1 s.
d. at this point you can have the stamp re-transmit the tachometer data digitally by a serial link to a wireless transmitter, an LCD display designed to handle serial data from the stamp, or any other device with a serial input (may need a conversion chip to shift the voltage levels).
The advantage to doing it this way is you have the data coming in digitally that is then processed by the stamp and then retransmitted to wherever using digital techniques. This means only one conversion is done and you do not have to worry about instrument drifting and any necessary re-calibration required.
HTH.
Gerry Shand
I think you will find it to be what you are looking for.
Thanks for the help.
