Hex issues — Parallax Forums
Hex issues
Brian MillerBrian Miller Posts: 25
edited 2004-09-22 01:49 in BASIC Stamp
Ok, my brain hurts....
I have a LED display driver that basically takes 5 nibs of data and displays the value in hex on each of the 5 digits.·I'm trying to display the time, but can't come up with a sensible way to get it to display in decimals. I shiftout the 3 bytes (the extra nib is for dp) the "secs" variable contains the current seconds from the clock. So you start getting 3c for 60 seconds and so on. The only think I can think of is to create a giant "DATA" array and map each second of 60 to the appropriate byte. I hope that makes sense??
The shiftout
SHIFTOUT pLED14489d, pLED14489c, MSBFIRST, [noparse][[/noparse]%10110000, %00000000, secs]
Newbie, using the NX-1000 24/40 Board with a BS2p40
  • K de JongK de Jong Posts: 154
    edited 2004-09-21 23:56
    Hi Brian,
    What if you try the following:
    seconds (units) LOWNIB.seconds
    seconds (tens) HIGHNIB.seconds
    Just a thought.....
    Klaus
    edited 2004-09-21 23:58
    Sorry,
    seconds (units) seconds.LOWNIB
    seconds (tens) seconds.HIGHNIB
    smile.gif))
  • Brian MillerBrian Miller Posts: 25
    edited 2004-09-22 00:08
    Yea, I tried that but realized that that will return 0-15 thus 0-F
  • CPUMANCPUMAN Posts: 55
    edited 2004-09-22 00:09
    Basically you'll want to use a math trick to get the right value to be displayed.· There is several ways to go about this.· I'd recommend just doing this...
    You could simply add 6 to the counter ever time it gets to $A (10) so that if it's say at $2A it'll add 6 making it $30 which will produce the desired output of 30 instead of 2A.· The only thing is you'll have to adjust your program to look for $60 (96) instead of 60.
    Chris
    edited 2004-09-22 01:34
    I wrote a demo for the chip a month or so ago -- perhaps my code will help.· You see that the DIG operator and using the \bits parameter with SHIFTOUT are very helpful.
    Jon Williams
    Dallas Office
    Thanks, that will learn me something. I have the thing counting right now. I will now go off in the code and "DIG" lol.gif for a better understanding! Thanks again!
