Why doesn't this work?
import stamp.core.*;
···· public class ex3 {
······ public static void main() {
·········· CPU.writePort (CPU.PORTA, (byte)0xF0);
I expect the above program to turn on 4 LEDs, but nothing turns on.
When I change it to CPU.writePin (CPU.pins[noparse][[/noparse]4], true); it works for all pins 0-7.
What am I doing wrong?· Do I have to set PORTA as output first?· How do I do that?· I don't see it anywhere in the manual.
Thanks.
Thanks.
CPU.writePin (CPU.pins[noparse][[/noparse]i], false); statement!!!
Is there an easier way to set PORTA to output (instead of individually writing a "false"·to each pin?)
I've modified the program to mimic StampWorks Exercise 3 in Java and this now works.
Note:· If i is declared as byte, then it loops forever.
········ int i;
········ int MinCount = 0;
········ int MaxCount = 255;
········ int DelayTime = 1000;
········ //byte j;
·········· for (i=0; i<8; i++){
············ CPU.writePin (CPU.pins[noparse][[/noparse]i], false); //set all pins·in CPU.PORTA as output &·low
·········· for (i=0; i<=255; i++){
·········· CPU.writePort (CPU.PORTA, (byte)i);······ //if i was declared as byte, it loops forever
·········· CPU.delay (DelayTime);
·· * Make a pin an input.
·· * The specified pin will be converted to an input. More than one pin can
·· * be specified using the + operator, as long as all pins are on the same
·· * port.
·· * @param portPin the pin to make into an input.
· public native static void setInput(int portPin);
There is also an undocumented public internal method setOutput
·· * Internal method. Do not use.
· public native static void setOutput(int portPin);
I guess it takes the same argument as setInput so you would write
setOutput(CPU.pin0+CPU.piin1+----+CPU.pin7) to make portA all outputs.
regards peter
CPU.setOutput (CPU.pin0 + ...+ CPU.pin7) works and so does
CPU.setOutput (CPU.pins[noparse][[/noparse]0] + CPU.pins[noparse][[/noparse]1] +....CPU.pins[noparse][[/noparse]7]).
So I wonder again why
····· final static int LEDpin = CPU.pin0;······works
but not
······ static int LEDpin = CPU.pins[noparse][[/noparse]0]; and final static int LEDpin = CPU.pins[noparse][[/noparse]0];
Anyone knows?··
because CPU.pin0 itself is a final static int.
static int LEDpin = CPU.pins[noparse][[/noparse]0]; should work
because LEDpin gets it value at runtime.
Please check that again and compare the
assigned value against CPU.pin0
Alternatively, you may put the assignment at the beginning of your main()
like
static int LEDpin;
· LEDpin = CPU.pins[noparse][[/noparse]0];
· //other code
because the moment main() is executed you know that all classes
are initialized regarding globals.
regards peter
