Fish-finder/Echo-sounder
I know·the theory of how·these things work as I've been around boats since I was a toddler, but have never found any good schematics for them.
Does anyone know of any schematics which could be adapted for use with a BS2p and a row of leds to indicate how deep the water is?
It would be quite nice to have something like this in my cayak, particularly if I could get a decent short-range resolution.
(I particulary want to know when I have depths less than 4feet under me as a capsize in such shallow depths can be quite dangerous... )
It's already setup to interface with a microcontroller.· The stamp programming should be pretty straight-forward, something like:·
Hope this helps
p.s. a feedback loop (with RC circuit)·would be required from pin 0 to 1 to allow the PULSIN to trigger properly.
"OIOOIOOO OIIOOIOI OIIOIIOO OIIOIIOO OIIOIIII OOIOOOOO OIIIOIII OIIOIIII OIIIOOIO OIIOIIOO OIIOOIOO OOIOOOOI"
I've looked it over, and the electronics doesn't look too weird.
Most commercial fish-finders allows you to place the transducer on the inside of the hull if it's plastic or fibreglass, as long as you use epoxy and make certain there's no air bubbles trapped in the glue.
I'll try to track down the components and see what kind of abuse they can take...
