Solar powered & other independent/remote projects
I'm just wondering·how many·of you people have used·a BASIC Stamp in a·solar powered·/ remotely located·/ marine project...
I want to know how well the stamp can withstand adverse weather conditions (temperature extremes, humidity, etc.).
Please, share your·stories·about any·projects like this.
Sheldon
Sheldon
So long as your project or product is hermetically sealed, there shouldn't be any problems with outdoor, marine use. I've used PVC enclosures sealed with GE RTV compund or other similar sealants with great result. It's also reentrant by merely slicing through the sealant with a razor, if necessary, at a later point in time.
You may be interested in knowing that the BS-2 Stamp is available in and industrial version which has extended temperature capabilities: - 40C --> + 85C (-40F --> 185F). The Industrial BS-2 Module can be found here:
http://www.parallax.com/detail.asp?product_id=BS2I-IC
Bruce Bates
Tracy Allen
www.emesystems.com
It is not a cure-all, though, because one pack of desiccant can only absorb so much moisture. That is fine if the box is really sealed, or hermetically sealed as Bruce pointed out. The entry of water vapor should be nil or so slow that the desiccant can keep up.
If an enclosure is exposed to the elements, especially outdoors with direct exposure to sun and sky, pressure changes inside a sealed box can be tremendous as the box heats up in the direct sun and then cools off under the night sky. The seals on the box and on the entry points for cables connectors etc. have to be exceptional in order to keep the flow of air and moisture out. Moisture that enters the box at night in the vaccuum conditions may not escape in the daytime. Pressure dropping and temperature cooling at night => condensation. You may come back to a "sealed" enclosure and find a puddle of water in the bottom.
For that reason, some people eschew complete sealing of the enclosure and put a vent in the bottom so that the pressure cannot build up. Gore (as in Gortex) sells expanded teflon vents for this purpose. It is a good idea to use double roofs or other techniques to lessen the temperature extremes and rates of change.
There is another consideration in solar powered systems, because usually the solar panel will be charging a battery located inside the enclosure, and the battery may give off gases including H2O that have to be vented. A good sealed battery properly float charged will not vent much, but it is really touch and go if the system needs to do any fast charging. A vented enclosure is essential for that.
-- Tracy
Tracy Allen
www.emesystems.com
|PLACE IN HOT OVEN AND DRY IT OUT TO RECHARGE. CAN BE REUSED
|MANY TIMES. IF IT IS IN PLASTIC REMOVE AND PUT IN A OVEN SAFE
|DISH TO DRY. I HAVE SOME I |HAVE BEEN REUSING FOR OVER 30 YEARS. SOME MILITARY |APPLICATIONS HAD SILICA GEL |IN SEALED PERFERATED SARDINE SIZE CANS TO FACILITATE RECHARGING.
|73
|SPENCE
|TestForum@parallax.com wrote:
|> In BASIC Stamp, KenM wrote:
|> Has anybody tried re-using a small packet of silica gel that is
|> commonly found in products where moisture is undesireable?
Take a look at : http://science.howstuffworks.com/question206.htm
for info and links to other dessicants
Larry
Don't use a 2'x2' box if you are just going to put the BOE in there.· Use a 3"PVC pipe cut short and capped at both ends with a small dessicant pack in it.
Something to note:· someone mentioned about daytime heating and nighttime cooling.· The pressure changes here create a "pumping" affect which if you have the slightest pinhole leak, can suck moisture in.· I can't go through and tell you all the physics of all this....but in the field we've opened NEMA rated boxes to find a couple inches of water in the bottom of the box.· (Those pinholes are good for drawing water in, but don't think for a second that the water will necessarily go back out the same hole!).
We had picked up a bunch of these boxes and were having problems with them all....mostly because they were used or had holes already predrilled (can't remember, but we tried sealing them as the holes were of no use to us).
Anyhow, sort of a novelty bandaide solution was to glue a balloon (used a condom at the time -- ribbed of course! I'm not selfish! haha) to the opening of the hole (glue the open edges to the inside of the box).
Now when the "pumping" would occur, there was enough relief with the balloon in the opening that no water was sucked in.· Kinda funny to watch the condom blow up in the middle of the day....Just remember they're not UV rated and there's no where near enough pressure change to blow it up!
I work with weather sensing equipment, so this obviously doesn't work on barometry boxes (you NEED an opening to the 'real world' in this case!).
Anyhow, if you are reusing old boxes that you find to be well oversized for what you need them for....try getting some 'cheese-cloth' (what old ladies wrap their herbs in to dry) and fill it will kitty litter or absorb-all or something like that (vermiculite??).· Leave it in the bottom of the box· and be sure to mount your electronics up out of the way (in case of a few inches of water getting in to the box that your electronics will not be sitting in it!).·
that's just a quick suggestion off the top of my head!·
I know people that put vaseline on their car battery terminals to stop oxidization....it's messy but not as perminant as silicon.
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
I'm very impressed by the methods you describe to keep wate out of your equipment boxes. You seal everything!!
In contrast to your methods I deliberately leave a small hole (3 to 5 mm) open at the bottom of the box. So, no vacuum, no pumping water in and if some water comes in it can go out easily.
The little bit of heat the electronics produce gives a lower relative humidity inside the box. So, to my exprience, there is actually no problem with condensation.
It works fine for me, even with the very fast weather changes we have here in the Netherlands!!
Klaus
I was wondering if anyone else had used this method ?
Terry
Seems like I have seen this method in old electronics... radios specifically, but not for keeping
out moisture (I don't think), but to stabilize a tuning coil or something. Many circuits I saw were
very liberal with the wax. Bottom line is that I don't think it would hurt anything, and it might
work to keep the moisture out...or in depending on how and when you applied the wax (grin)
Beau Schwabe Mask Designer II
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
But we still like a good tight seal (insert favorite Walrus joke) so that we don't end up with bugs or even snow inside that melts from the equipment heat.
Steve
Tja, arctic conditions is a special case, I would think.
But in more general
But in more general conditions it can sometimes be favorable to use a vent in stead trying to close a box as closed a box can be.
Try a small vent with a piece of pipe some inches downwards.
Klaus
http://www.pmc1.com/Capability.asp?CapabilityID=223&Cat1ID=84&Cat2ID=107
this is a quick google result.·
Steve
With these GoreTex vents sealing of equipment will be unnescessary in many cases. Especially if you put some heat into the box abslolutely no condensation will take place.
Klaus
The vent is the slotted object in the upper right hand corner.
Here is a link to a Gore descriptive data sheet: owlogic.com/pdfs/Gore-Membrane-vents.pdf
Tracy Allen
www.emesystems.com
We have worked with smoke detectors that are usually manufactured with a coating of wax, in particular over the high impedance electometer amplifier for the ionization chamber. As they are used in kitchens, they are otherwise quite sensitive to condensation from the humidity of cooking and other kitchen activities.
Tracy Allen
www.emesystems.com
Have opened many vehicle wire harnesses (Korean) and they use wax to keep moisture out of wire harness splices. A typical splice might be 3 or more wires joined together with a brass crimp.
Ken
concentrators towards the sun +/- 0.008 degrees with photo resistors.
The high-intensity flux of 1000 suns increases photovoltaic power output
by 1000 times. This flux will melt steel.
http://www.harbornet.com/sunflower/pvdish.html
Outdoor DC devices can have galvanic corrosion problems after more than
five years. From experience, silicone sealer, plastic pipe, hot glue,
etc. do not make hermetic seals. Steel surplus ammunition boxes work
dry. So does vented heat. The Stamp and Motor Mind C produce a lot of
heat. I am considering combining the micros with the shadow band photo
resistor eyes to drive the morning moisture off of the eye windows.
Several eye boxes have been invaded by colonies of tiny ants. I plugged
and replaced drain holes with very fine faucet screens.
The next Stamp will use a clock DS1307 and EEPROM to track the sun
through the clouds with data stored from solar dish positions on
previous sunny days. Also Stamp controlled and monitored: water delta
pressure, flux temperature, power output, tracking accuracy with auto
correction, clock reset via sun position, and massive error checking
routines. The large solar dish is a dangerous autonomous robot that can
(and did) start fires, burn people, and self destruct. A daunting task
for an amateur Stamp programmer
On the other hand, down here in Antarctica, even with close to no humidity, electronics will still corrode if snow or ice gets in through the tiniest hole, as the heat from working electronics will usually be just enough to let things corrode.
Sometimes a double-container system works well, the outer one as a general buffer against driven weather, the inner one to keep the electronics dry/free of snow etc.
How about some pics from where you work/live?
Mount Erebus, Antarcticas only active volcano.
Aurora Australis, we get a lot of them in winter. We are only just getting to see the sun now for the first time in 4 months.
Post Edited (Antz) : 9/2/2004 8:55:55 PM GMT
http://sales.goldmine-elec.com/prodinfo.asp?prodid=3252
Post Edited (Jonny555) : 9/2/2004 1:23:30 AM GMT
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
The company mentioned in the Electronics Goldmine ad, Minco, has a web site here:
http://www.minco.com/
That might be a good place to start your research on poawer requirements.
Bruce Bates
Temperatures below -40 are going to cause all sorts of headaches eventually.
The main problem a lot of systems have is micro-fractures on the circuit boards or in components due to temperature changes. The transition from around freezing down to -40 is pretty hard on the gear. If things can be kept at a reasonably constant temperature they are usually ok once they settle in.
In terms of moving parts, it is oftem best to run them with no lubrication, as a lot of lubricants turn sticky when it gets really cold.
PS: I reloaded the pics on the previous post.
Post Edited (Antz) : 9/3/2004 4:20:28 AM GMT
Big thanks to parallax... man these guys offer so much help it makes me proud to incorporate their products into my vision hehe. I can just imagine the sick demented creations others may be conjuring up with these micros.
Which brings me to my next thought...
Solar Panels, epoxy coated(heavy) or flexible(can be rolled onto a 2" pipe).
I can picture neat mechanical devices to deploy panels from a hatch of some sort either way.
But how to protect panels from harsh temperatures and varying weather...
Not sure how they do in extreme heat.
