math help needed
hi ,
i have a math problem and need some help to solve it
i have two numbers :
a=90000000 and b=75000000
both of the numbers are divided in high· and low like
a= 9000 high and 0000 low. the same for b.
i have also a limit level like c=1567
b it will increment if an event happen
i would like to monitor b in a such way that when a-b=c to get an output or alarm or a conditional branch to do something.
thanks
ion
thanks
ion
Thanks to Tracy Allen, here is a tutorial on how to do double precision (32 bit) math with the Basic Stamp:
http://www.emesystems.com/BS2math6.htm
Bruce Bates
a0 VAR Word a1 VAR Word b0 VAR Word b1 VAR Word c1 VAR Word c0 VAR Word a1 = 9000 : a0 = 0000 b1 = 7500 : b0 = 0000 DO b0=b0+1 IF b0 >= 10000 THEN b0 = b0-10000 : b1= b1+1 ' carry c0 = a0 - b0 IF c0.bit15 THEN c0 = c0 + 10000 : c1 = c1-1 ' borrow IF c0 = 1567 AND c1=0 THEN DEBUG "wowzer!" LOOPIf you let that loop run, it should print "wowzer" on your screen after a wait of about 12 hours!
Tracy Allen
www.emesystems.com
Iwill go to that site and do my home work. You save me a lot of headeche
Thank again
ion
Jon Williams
Dallas Office
The symbols b0 and b1 would point to the same space in the RAM as a0.byte0 and a1.byte1.
Tracy Allen
www.emesystems.com
