(Unwanted) Blinking Outputs
While creating a circuit with LEDs, I noticed that when applying power the LEDs would start to blink rapidly. At first I thought it was the BASIC Stamp overloading or something because I have the LEDs connected directly from Vdd to Vss w/ out a 470 Ohm resister like all the manuals say you should. But then I Made a circuit without the stamp at all and the blinking still happened. Does anyone know why this is? I would assume its not a good sign.
Actually, yes. Your P/S--Power Supply, could be at fault. One of your capacitors could be going. What kind of supply is it?
Buck Rogers
www.gregg.levine.name
The caps your talking about, like the ones built into the BOE rev C that Im using?
Yes exactly. I've seen caps get punctured from too much voltage past their ratings. These are polarized electrolytics that I am writing about here. They typically contain a specific dielectric or insulating compound, to create that compound, a voltage is applied a certain way. And your power supply is a wall wart that the company provided, so that's not a problem. Not yet.
Also I have seen my BS1 stamp cause the blinking to happen when first started up, it was executing the last written program, which happened to be one of that sort.
Buck Rogers
from your first E-mail on this topic....
... w/ out a 470 Ohm? I think that you SHOULD have a 470 Ohm on each LED otherwise the LEDs might draw enough power to drop the voltage
enough that the STAMP will go into reset mode.
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
You said you connected the LEDs from Vdd to Vss without an inline resistor. That results in a virtual short for the LED and will burn out a regular LED. Note: resistors are used to restrict the amount of current flow through a device.
But your LEDs are not burned out. That means there is some form of inline resistor or current limiter.
Where did you get these LEDs? I know they make blinking LEDs. I've never played with them. Maybe they do not require inline resistors because the resistor and blink circuit is built into them.
Note for the future. If you do not use a resistor in-line with a regular LED you will burn out the LED. If it's connected to a Stamp there is a good possibility you'll burn out the Stamp pin.
Get some resistors.
······ Bob, Ottawa
W75 54 17·· N45 18 30
·········· G16 #27
If you want to learn more about this sort of thing, drop by http://www.al-williams.com/classroom/course/view.php?id=4.
Al Williams
AWC
Kits!
http://www.awce.com/kits.htm
P.S. Whoops. Too early. Said 5V resistors instead of 5V LEDs :-) Good thing for editing!
Post Edited (Al Williams/AWC) : 8/31/2004 1:44:58 PM GMT
Harry
I have a few here, as well. They've got the blinking device stuck off center to the regular LED chip.
Also Agilent makes LEDs with the resistors installed already,
Buck Rogers
Hmm, Ill try looking for those 5V LEDs. They must have been made for the lazy folks, lol.
Jon Williams
Dallas Office
