IRL 520 Driver
Thanks to all who provided info and help with my schematics for the IRL 520 Driver!!!
I have put together a driver board, designed with ExpressPCB.
Would someone mind taking a look at the board layout for any mistakes?
Also, the booard will be driving solenoids using 12 volts.· How do I figure out what value resistor to use to power my indivator leds from the same 12 volt supply line?
THanks again for the help.
Rus
Rus
Pin 1 of the VR is Input, Pin 2 is ground and Pin 3 is output.· That's for a start.
Use a 12 volt LED with a 220 ohm resistor.
Sid Weaver
Pluggable Serial Backpack
http://hometown.aol.com/newzed/index.html
There are no VRs on the board.· The transistors are IRL520 Mosfets.· Pin1 is gate, Pin2 is drain, Pin3 is is Source.
Rus
Sid
I really should go in and change that part number.
Rus
Ken.
See notes in the private message
Rather than having to wire a stamp to it I have integrated the OEMBS2.
I have also added an LM2940CT-12 voltage regulator (12vdc 1amp) to power both the stamp and the solenoids.· I added a 22pf Electrolytic Cap fromthe output to ground as suggested by the Vreg manufacturer spec sheets.· Should I also add a .47pf cap to the supply side of the Vreg? This will be powered by a wall wart.· The OEMBS2 has a regulator that would then regulate this down to the required 5volts.
Do you foresee any problems designing the board this way?
Should I stick with separate power supplies for the driver board and stamp?
Attached is the PCB layout in ExpressPCB
"My mind wanders...I'm just along for the ride!
Sid Weaver
I am supplying 12 volts to the Vss pin on the stamp and allowing the onboard stamp regulator to regulate it down to 5.
Rus
if you put a potential on the vss pin then you risk a reverse polarity situation.
also you should take advantage of your board space and spread out you components.
and lay out your components in a nice neat manner before you run your traces because you should make your end product look nice to random joes that dont know jack a/b pcbs. you can usually route your traces to suit any layout. i attached a petty example w/o traces...
also, if your going with the proto service, put lots of silkscreen lables to make your design very user friendly
rox on
nick B
How would you recommend powering the stamp?·
RUs
vdd = +5v or Vin = 16 to 24v
rox on
nick B
Sometimes I'm jsut a moron.· I misspoke.
For once I actually had it right.· On the Board Vin is connected to the external regulator 12+ output and Vss is to ground.
Rus
just messin with ya dude
