Sherline milling machines
Well, as it goes, I am in the market for a small, tabletop milling machine. I basically have decided to purchase either the Model 5000 (5100) or the Model 5400/5410 Deluxe mill. So, I would like to know if anyone here owns either or both of these mills (or knows someone who does), and which if the two you/they would recommend. Additionally, I would like to know if anyone thinks that a CNC upgrade for either is worth it, for simple robot chassis/wheel hub/frame work, or is it just a waste of money making a simple thing even simpler than it needs to be?
Oh, and before anone recommends me looking around at other milling machines first, I have, for almost 2 years now, and I am very set on the small/affordable/durable/trustworthy qualities of the sherline series of milling machines, unless of course someone has some extremely super-duper milling machine recommendation that would blow these away in all qualities, then I will be open for a change of mind
Anyway, thanks in advance anyone who responds!
.Anyway, thanks in advance anyone who responds!
In any case, be prepared to spend far more for the necessary accessories than you do for the milling machine.
HTH
I used to be different, but now I'm the same...
Also, Sherline mentions a complete CNC package for $2500US. This seems reasonalble (includes a computer?) as getting software integrated with a DIY system might be a real snag in the learning curve. If you want to build robotics - not CNC, buy the package and stay with studying PBasic.
Also, they have a rotary table add on to the CNC.
Many years ago I did business with Harbor Freight for wood working machinery (a small table saw and a small planer) They were okay and the price was right, but I later moved up to much better equipement.
If you can afford first rate to start with, you waste less time and money. And you learn much faster. How can one learn piano if it is always out of tune?
G. Herzog in Taiwan
Sherline really steals the show with their support, kind of like Parallax. They certainly have a lot of good tools which makes them like us except for machine tools. I've seen their machines in use in many places and a few friends have them. They can do quite a bit if you take the time. It's a lightweight machine, but if you are like many others getting started it will be a while before you exceed the machine's capabilities. Or, there's another theory. . which is that the machine can hold you back from growing as a machinist because of its limitations.
Truthfully, if you can afford it I'd step up to a heavier brand from either Taiwan or Germany. My favorite is Wabeco:
http://www.kengracey.com/wabeco_mill_drainpan.asp
http://www.parallax.com/html_pages/robotics/machining/machining.asp
But there's another great value if you can't spend this kind of money. Having researched these quite a bit, I've found some very good quality machines from Microkinetics:
http://www.microkinetics.com/
Not that Sherline won't be good, but it is a lighter machine. The most apparent limitations will probably be the size of work you can hold, the amount of cutting you can do, etc. but when it comes to standard tooling they've got a huge selection to choose from at a fair price.
Oh, most importantly is that I've seen these get sold on eBay for some pretty low prices. Check there first, and know what you're bidding on.
