What happens at the end of a program? — Parallax Forums
DonDon Posts: 34
edited 2004-08-18 23:15 in BASIC Stamp
What does the Stamp do if you let it "run off the end" of your program.· Consider this trivial, but complete,·program:
I Var Byte
I = 3
So what happens after the 'I=3' is executed?· Is there an implicit 'End' instruction·at the end of every program?· The manual hints that this is so.
Don Kinzer
    Yes, the program ends, though "good form" suggests we put END into our code. Unused EEPROM locations are written as zero, the same token for the keyword END.
    Jon Williams
    Dallas Office
