Safe testing with LEDs
LoopyByteloose
I have a microcontroller (in a radio controlled reciever)·that I want to test the outputs for ground or +5.
Can I use any old LED and a 470ohm resistor to verify the outputs?
My thinking is that the resistor will safely limit the current in the forward direction and that if the LED is backwards, the diode function will prevent and damaging reverse current.
Or, is there a risk that I will hurt the microcontroller?
I don't have a scope.· And, the instructions are in Chinese.
There are no specifications for maximum current outputs, so I am assuming 20ma and trying to use only 10ma.
I am having to·reverse engineering this.
Any· useful tips on how to safely do this kind of thing would be welcome.
I had planned to use it as a remote control with the Basic Stamp once I verified the logic.
G. Herzog in Taiwan
It is much safer than misreading the value (in fact, I think I should get a capacitance meter for the same reason)
I just got back to the device to try 1K, but I found it is all working fine with the 470ohms.
The real problem is that I am not used to making good, solid connections with the breadboarding.
It seems that the resistor leads are not the idea 22 gage wire.
I spent a lot of time thinking about all this and nothing beats having a scope.
(I had an old Textronics 'boatanchor' that weighed about 75 pounds, but it was really well designed and stable)
G. Herzog in Taiwan
