Boe-Bot substitute.
                    Hewwo, all.· I unfortunetly don't have the money to buy the Boe-Bot kit.· I wish I did though.· But sinse I don't, I would like to know if there is a way I could make a sort of "make shift" Boe-Bot.· Is there a way to do this?· Thanks for your help.
Made out of extra parts, double sided tape, and 2 cd's.
Whelzorn, how do I make a link in here?
Thanx bro
http://www.parallax.com/html_pages/products/basicstamps/basic_stamps_oem.asp
The OEM modules are fully functional BASIC Stamp®
Also try
http://www.phanderson.com/stamp/bs2_homebrew.html.
Peter Anderson sells them.
#1 if possible always buy from parallax over radioshack.
But in this case since you're on a budget you might want to do some shopping at radioshack to save on shipping cost.
I am pretty sure you should already have pretty much all the components needed, except the 4.7k resistors and the IR LED's/ receivers, and the servo's.
You can get the IR LED's/receivers, and the resistors from parallax or radioshack (if you need to save on shipping costs) sorry I dont have the Item #'s as I threw away the packages. For the servos you wont find them anywhere cheaper than parallax.
As for the chasis, you can buy a premade one parallax, buy sheet aluminum and cut one out, or you can be creative and use acrylic (or plexiglass, its the same thing to me), lowes sells it fairly cheap. For 10 bucks you can get a sheet of it big enough to make a couple chasis.
The only tricky thing with the acrylic is bending it/joining it which will be necessary for making a chasis. Ive personally never bent a peice of acrylic but ive seen it done. Bassically youll need some kind of heat source, this could be a soldering iron, a torch, a heat gun (NOT a hairdrier), a candle lighter, etc. You apply (indirect) heat to the acrylic and once hot (almost molten) you can bend it to the desired shape. NOTE- if you try this make sure you use gloves as to not burn yourself.
For cutting out the acrylic you can use a number of things, jigsaw, bandsaw, skillsaw, hacksaw, coping saw, a file, etc etc. I find a jigsaw to be pretty easy, just have the blade going at about medium speed and just take your time, but if you go too slow and the acrylic melts from the heat generated by friction between the blade/acrylic.
For drilling the acrylic I prefer taking a scrap peice of wood and clamping it down to it, then use a electric drill and at about medium-high speed go after it. NOTE-if you have the drill running to slowly it will end up cracking the acrylic. Also, dont use a drill press, ive tried it and 8 times out of 10 you'll crack the acrylic, I beleive it has too much torq and goes too slow.
One more thing, after you finish cutting, bending, drilling, what-have-you, take a peice of about 800 grit (wet/dry) sandpaper and wetsand all the edges of the acrylic so they have a nice smooth surface. If you want you can even use about 320 grit sandpaper and dry sand it (but it wont look as good).
Hope I helped and didnt just get you all confused.
Jon Williams
Dallas Office
Jon Williams
Dallas Office
http://www.lightlink.com/dream/chris/boebots.htm
Someday I want to get a toddler, and perhaps, if I win the Lotto, a Hex Crawler.·
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
