? about temp sensor
· I recently bought a LM34 TEMPERATURE PROBE and a basic 2 stamp (BOE).· Just wondering if the two are compatible?· If so, how is it wired to the bs2?
·· thanks in advance.
Jon Williams
Dallas Office
Well, it is not quite true that you can't use the LM34 with the BS2 without an analog to digital converter. The LM34 can be configured with a resistor to output a current proportional to temperature, and then you can use the Stamp's native RCtime command to read the temperature. (The Applied Sensors text has lots of information about how to use the RCtime command.)
- - Tracy
Tracy Allen
www.emesystems.com
Al Williams
AWC
8 Channels of PWM
http://www.awce.com/pak5.htm
You can download that text from the link below, thanks to Parallax!
http://www.parallax.com/detail.asp?product_id=28127
Bruce Bates
