Controlling the temperature
Hello,
I'm using a basic stamp 2p40 to measure temperature and humidity in a growchamber.·The growchamber is an aquarium (no water in it
·), size 60*30*30 cm (30·cm is almost 1 foot)
But now I'm planning to keep the temperature in this growchamber at a constant level; now the question is: what heater/cooler devices can be used?
It doesn't have to be a very sophisticated product, e.g. a thermostat isn't necessary; after all, the basic stamp already measures the temperature, thus this value can be used to control the heater/cooler, e.g. by turning it on and off.
Thanks in advance!
Erik
·), size 60*30*30 cm (30·cm is almost 1 foot)But now I'm planning to keep the temperature in this growchamber at a constant level; now the question is: what heater/cooler devices can be used?
Thanks in advance!
Erik
Jon Williams
Dallas Office
Use one of the shatterproof incandescent bulbs with the clear Teflon or clear plastic coating and you should be okay. They generally go by names like this: CoverGuard, ShatterPruf, Safe-T-Lite. You'll know immediately by touching the surface of the bulb before you buy it. It will also look quite dull in color/texture due to the plastic coating.
Bruce Bates
·· Would a bulb such as the ones you describe run as hot as a standard bulb?· Or are they cooler?· Just curious, having a plastic coating...I would think they would run cooler, which may defeat the purpose.· I have never seen/used such a bulb to know.
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Jon Williams
Dallas Office
Just by the very nature of a given sized filament within a given sized envelope, the heat (wattage or power) will remain the same. In fact, if anything, it may produce more heat in that it could retain the heat longer than an ordinary bulb which will cool naturally by heat convection on the bare glass envelope.
Bruce
·· Thanks for the info...That would answer the question for anyone else wondering as well.·
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
