Programing BS2p
Hi,
I am trying to write a BS2p software to read data from a synch serial input from an 8-bit register 74LS166A, but it can't really·work. Any one can help, plz.
The problem is at CLK INH that requires 2 high pulse during reading·the 1st and 2nd bit of the 8 bit data.
Many thanks
Many thanks
1. Tie the Clock Inhibit (CLK INH) line low, and the CLR line high -- you don't need to control these lines
2. (with the BASIC Stamp) pull the SH/LD line low, then do a PUSLOUT on the clock line -- this will load the parallel inputs
3. Use SHIFTIN to grab the data
Sorry, I don't have a 74LS166A -- otherwise I'd write a snippet of code for you.
Jon Williams
Dallas Office
Seems like·the prob.·is more complicated,
CLK INH=hi activate LOAD and·READ
of FIRST, whereas to read·2 - 8 bit need CLK INH to be low and reading start at next leading edge of CLK.
Maybe I may need two SHIFTIN, 1st to read 1st Bit at setting CLK INH hi, then 2nd SHIFTIN to read 2-8 bit by sending PULSOUT and setting CLK INH low
Attached is the pulse diagram for 74LS166A.·Thanks again
Jon Williams
Dallas Office
Jon Williams
Dallas Office
Jon Williams
Dallas Office
Post Edited (Jon Williams) : 8/7/2004 11:29:30 PM GMT
Jon Williams
Dallas Office
