Portable Tachometer for spinning Helicopter Rotor
Hey you
I just got my BS2 with homework board and been toying around with leds and servos. My real , serious proyect is to make an optical tachometer to measure the RPM on a flying RC Helicopter ( 1400 - 1600 RPM 2 blades ) . I got the software somewhat designed but still looking for the correct hardware - chips - etc to count the blades passing ,.... any help out there ???
by the way ,... TWO THUMPS UP Parallax ,... Basic Stamp a GREAT product and Concept.
Thank you
Francisco
Hey youI just got my BS2 with homework board and been toying around with leds and servos. My real , serious proyect is to make an optical tachometer to measure the RPM on a flying RC Helicopter ( 1400 - 1600 RPM 2 blades ) . I got the software somewhat designed but still looking for the correct hardware - chips - etc to count the blades passing ,.... any help out there ???
Thank you
Francisco
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4678&item=3830941989
I don't have a lot of constructive advice about the tachometer. The Stamp can resolve pulses using PULSIN. The size of your pulse will depend on the speed and the arrangment you use to sense the blade (and probably the width of the blade). If you need something that runs all the time, I know quite a few of our PAK-VII·chips are used for tachometry. The advantage is they read data all the time even when the Stamp is busy doing something else.
Al Williams
AWC
http://www.awce.com
And thanks Al ,.... impressive line of products you got on your web ,... ! I want them ALL !!! and it is not a joke ... still want to go back there and verify everything once more. ( Already donloaded all the docs you offer ) ... You are right about your friends example ,... i am one of those ..., simple as that !!!!
The problem i have is what photransistor or the like to use ,to get the pulses signal............, i already thoght about your coprocessor,....of course.
I am in Chile but still find your prices very well put , congrats.
Franciso
Chile
Probably the best solution would be to beam some modulated IR up at the blades and watch for it to bounce back. There are some all in one IR demodulators/detectors used in IR remote controls that are inexpensive or that can be salvaged from old remote controlled gear. Look up IROD or IRODS on the Web and you'll see what I mean. This should work day or night and be immune to stray light hitting the sensors. I'm not sure how good the dynamic range is if you are hitting it with full daylight and then a brief IR burst. Another idea, if you are onboard, is to not look at the blades, but instead look at the rotor shaft, where you could be "inside" and out of the ambient light. That would make things much simpler to do optically. You might even get away with magnetic there since I doubt you would imbalance the shaft. In fact, if you were going to do that, you could actually put a small wheel around the shaft like the one in a mouse. The wheel would have one or more slits to pass light and you would count the speed at which the slit passed. That would allow you to have very good slow resolution, but I doubt you really need that.
Maybe someone with practical experience will pipe up with some better suggestions.
Al Williams
AWC
* Floating point math for the Stamp
http://www.awce.com/pak12.htm
later i will investigate on sensors
Thank you for your comments
Hope this helps
"OIOOIOOO OIIOOIOI OIIOIIOO OIIOIIOO OIIOIIII OOIOOOOO OIIIOIII OIIOIIII OIIIOOIO OIIOIIOO OIIOOIOO OOIOOOOI"
If you can attach a magnet somewhere this approach could work really well:
http://www.parallax.com/html_pages/robotics/machining/RPM_display.asp
You could use one magnet on any rotating part. I can attest that it works really well for my milling machine.
Sincerely,
greetings
Francisco
I wil let you know
And I want to say it again : Wonderfull product and concept your Basic Stamp !!
so long
Francisco
Thats it
hu
But to answer your question on the optics, there are a few sensors that would do what you want. A phototransistor is probably your best bet.· They also make "optointerruptors" that have an LED and phototransistor (and maybe some logic) with a slot for your piece to move between. They also make reflective optointerruptors. But you can always just make your own from an LED and a phototransistor.
Al Williams
AWC
Control 8 servos at once!
http://www.awce.com/pak8.htm
So even with the beam blocked by the interrupting medium, the phototransistor does not turn off. This has often occured even when attempting to put the phototransistor recessed in a cavity to shield it from ambient light.
Are there specific optos that are less sensitive to ambient sunlight? Or am I imagining something wrong and there is another possibe reason for the photointerruptor not working in bright sunlight?
Ken
Not to say that magnetic would not work also and avoid the light problem alltogether.
Al Williams
AWC
Easy RS232 Prototypes
http://www.awce.com/rs1.htm
And I definitely need that Coproc. , the one with A/D an comparator.....must figure out how to bring one home.
so long
Thank you all guys, never thoght such a forum could be this productive.
sorry my poor english , thats all there is to it.
Francisco
Naval Mech. Engineer
Chile
We all agree , I will go Hall - Magnetics.
Francisco
If you are in Chile I can forward the parts to our distributor Rambal and he can get them to you. These components cost only a few dollars in the U.S. and I have some extra samples at home. All I need to do is put them in the next order from Rambal and you will have them. I imagine he'd charge you a few dollars or so. Let me know if you want me to do this for you.
Sincerely,
a few dollars ??? how much is a few for you ??? .... The answer is yes , of course . Hope Rambal people do not want to take advantage ...
By the way , I went there ( about 500 km away from my city ) , just to talk with them. I did it as soon as i knew they where Parallax distributors for Chile. I wanted to know if they could support me in starting an educational program in my city based on the hardware you make. This proyect is something i wanted to do for many years now and the Parallax Stamp and its Concept made such a good impression on me that i think now it is the time to fullfill that dream. I think that this activity ( micros programming and the like ) is an excellent choice for youngsters with technical apetite and the best way to keep them away from too much TV , solo Game playing on Pc , etc.
If you can do what you are offering , i will be delighted , just let me know when the time has come.
greetings
Francisco
Send me your shipping address kgracey@parallax.com and I'll send the parts directly to you, bypassing Rambal to keep this simple. I'll use USPS shipping. No charge for the parts.
Did Rambal agree to support your efforts with education? I sure hope so and if not I'll have to talk with Jose!
Ken
As for Rambal supporting me ,... they did agree , yes .... ,..... partly,.......
I bought an "BS2 Homework board" from them for my personal use and headed back home. Did not get anything else only because i am not a rich man and must plan carefully to make this kinda things. I wanted to test the Stamps potential and Programming environment myself . IT IS EXACTLY HOW YOU ARE ADVERTISING IT !!!!! Bravo !!!
I guess it is not easy to do better for them...... consider the fact that some crazy day an unknown fellow comes out of the clear blue sky saying he wants to teach Basic Stamps.... we talked for about 1 hour and I must say it was a pleasant meeting though.
I wil come back to you via mail.
Thanks for your interest and supportive , helping attitude.
a thankfull Francisco
Chile
· ...is dead! Anyone got an alternate source of info??
························ Hacking the Trailing Edge!
················http://www.nmpproducts.com/intro.htm
················---Decks a-wash in a sea of words---
Parallax Inc.
