Telephone Line Powered SX
william chan
Hi,
Any of you geniuses have any ideas on the feasibility of running a 50Mhz SX28 from the telephone line power?
The circuit will have to charge a rechargable battery when the phone line is in use, without disrupting the normal operation of the telephone.
Of course the SX will have to sleep most of the time or be able to change it's own oscillation frequency.
Thanks.
Thanks.
For example, I remember the phone line measuring about 48 volts dc with nothing connected, then droped to less than 10 with the phone connected.
From the size of phone line wire it looks like it will not carry much current.
Can you go into more detail about the project, do you have to run the sx at 50 MHZ?
Ken
If we want the SX to do DTMF Detection and DTMF Generation, it probably need to run at 50Mhz or somewhere near there.
The SX uses about 80mA when running 50Mhz at 5V, so definitely we need rechargable batteries to help out
Do you know of any simple circuits to steal currrent from the phone line?
Do u know of any method for the SX to change it's oscillating freq during run-time?
Thanks.
William
Regarding changing the osc freq during runtime.....I don't know if that can be done, but some of the SX gurus will likely chime in and let you know about that.
One suggestion is to visit www.sxlist.com and see what they have there about DTMF.
Ken
qouting http://www.sandman.com/telco.html
that last one is funny,·all of their products don't actually "run" on the phone line, they just·trickle-charge batteries.
This link will probably be most helpful: ·http://www.epanorama.net/links/telephone.html
"OIOOIOOO OIIOOIOI OIIOIIOO OIIOIIOO OIIOIIII OOIOOOOO OIIIOIII OIIOIIII OIIIOOIO OIIOIIOO OIIOOIOO OOIOOOOI"
Thank you for your most informative response.
We know that you can't take more than 0.5 mA from the phone line without causing the problems you mentioned.
But we can take 20mA or more DC when the phone is offhook ( in use ).
So, our plan is to charge the batteries whenever the line is in use, and stop charging when the phone is not in use.
The link you provided doesn't seem to have such a circuit.
Thanks.
William
All the best,
- Mike
Thanks very much for the circuit.
Seems like the bridge rectifier serves to charge the 1000uF Capacitor when the phone is offhook.
Very smart.
But, since the negative output of the bridge is grounded, this circuit will be a problem if more than 1 phone line is connected to multiples of this circuit.
B'cos they share the same ground, short-circuits and cross-talks between phone lines will be a problem.
I also noticed that there is no gyrator or coil to reduce attenuation of the AC (voice) signals when charging is taking place.
Is this normal?
William
The 'ground' is not earth, just a local buss. If you want to use multiple phone lines with the same micro you will have problems with this circuit and will need to design one that isolates each line - not an easy task and still be line powered.
The voice signals in such a series circuit are varying current, so the cap 'filters' and smoothes the modulation and a coil or gyrator was not need in the application.
- Mike
