DTMF Filtering
Hi everyone,
I have a problem with DTMF decoding.· I am sending DTMF tones to an MT8880 from a BS2.· Everything works ok when I send it directly from the pic to the 8880 but it has to be wireless.· I had two T5620's (Motorola two-way radios)and only when the volume was turned all the way down did it work.· For some reason if it was turned up a little bit it would not work.· I can't use those radios so I bought another pair, T4525's.· I can't get the volume down as low as the T5620's.· My question is, is there a way to filter the incoming DTMF tones to an acceptable level so the 8880 can decode them?
Chris
Chris
Horace
