Transmitting Data — Parallax Forums
Transmitting Data
de173de173 Posts: 4
edited 2004-07-30 20:47 in BASIC Stamp
Can i transmit any data from/to my boe-bot (bs2) with the 433.92 MHz Receiver RF or Transmitter to/from my PC?
Save me from MADNESS! :@
  • NewzedNewzed Posts: 2,503
    edited 2004-07-30 12:46
    You will need another Stamp connected to your PC to interpret data.· It may be possible to write a program for the PC that will receive the data directly without the Stamp interface, but that is way beyond you and I.
    Sid Weaver
    check out our 4-digit serial LED
    http://hometown.aol.com/newzed/index.html
  • de173de173 Posts: 4
    edited 2004-07-30 19:07
    I thought of using my second Stamp in order to do this. So I suppose it is workable. Sorry for asking so much questions but being in a foreing country (Greece specifically) I cannot order something that it will not work in the end. I've only seen the project that "Mr. Roboto" shows, in pdf format from the site. And it's just a simple control remotely of the bs2 (of course from another bs2 stamp).
  • cabojoecabojoe Posts: 72
    · I recommend the Surelink modules from Parallax. With a slower rf data rate enabled, you can transmit and receive at up to 1000 feet,instead of 250 feet,·for around the same price. Check out the BOE_DAR page on Parallax. If buying the Surelink transceivers, I recommend buying·at least·one Quicklink module so you can program the surelink modules for standalone mode. With a quicklink\surelink module on your pc side, and a surelink module on your boebot, and a little VB magic there is no reason that this can't be done.
    http://www.parallax.com/html_pages/resources/custapps/app_Boe-Dar.asp
