High Speed Square Wave Pulse Output (20kHz)
I have a BS2 and I need to provide a square wave 0 to 5 volt square wave to drive a stepping motor drive. Not a driver chip, but a complete drive that requires a 0 to 5 volt square wave. I need the high frequency output pulse train to drive the motor above 2400 rpm.
Has anyone developed a circuit for this type of application. I have used the FREQOUT and PULSOUT commands with no luck in reaching my top speed of 20kHz. I used the FREQOUT with a Schmitt Trigger but because the FREQOUT is generated via a·PWM the drive did not run in sink with the frequency. Any ideas?
Larry·
Larry·
Al Williams
AWC
* Kits! http://www.awce.com/kits.htm
